Interesting in Hondata.
Old Jan 23, 2005 | 02:42 AM
Root79's Avatar
Default Interesting in Hondata.
After a lot of engine swaps, wana did next step in to tuning.
Because there are some problems, which can be turn away only with program able devices. No expirence in that way. I must to teach for fuel/air maping very fast. No concurrent in this way here around. Nobody instal chap sytems. Especialy for Honda, nothing clouse. So, I have all open roads. Thats why searching in web, talking with local dyno ovners and must to start understand something. There are nothing difficult or impossible. Read almust all Hondata page, there are some explining and teach. Hear only one side expirence, that this sytem is very good and there are nothin better.....bla...bla....bla.......
Could be great hear more good and bad info about Hondata sytems.
Old Jan 23, 2005 | 04:56 AM
NJIN BUILDR's Avatar
Default Re: Interesting in Hondata. (Root79)
You won't go wrong with Hondata.There are other options,but Hondata offers good drivability and reliability.If you want all the options and tune it your self it is not the cheapest.AEM offers a competitive unit but reliability doesn't seem as good and idle quality is harder to achieve.
Glenn
Old Jan 23, 2005 | 05:52 AM
JdmEKCivic's Avatar
Default Re: Interesting in Hondata. (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">You won't go wrong with Hondata.There are other options,but Hondata offers good drivability and reliability.If you want all the options and tune it your self it is not the cheapest.AEM offers a competitive unit but reliability doesn't seem as good and idle quality is harder to achieve.
Glenn</TD></TR></TABLE>
That man speaks the truth, i had hondata and loved it, my car idled so smooth and made power from 1000- redline
Old Jan 23, 2005 | 06:30 AM
Padawan's Avatar
Darth ModerVader
If you are interested in trying to tune a programable ECU by yourself, I would suggest you put together an Uberdata setup. It has all the basic functionality of Hondata, but it's completely free.
Old Jan 23, 2005 | 12:00 PM
Root79's Avatar
Default Re: Interesting in Hondata. (Padawan)
Thank's. Did you know some non real time maping programs for chip tuning? I gues I will go with Hondata any way. But non real time programs have some interest for me too. Going to buy wideband lamda for begining. Wana see some AFR numbers by my self.
Old Jan 23, 2005 | 03:55 PM
Root79's Avatar
Anyone!
For Atmel chip programing.
Old Jan 24, 2005 | 11:46 PM
Root79's Avatar
Problem.
Need to tune up the OBD-0 ECU. Instal Turbo system on D16A6 engine. Stock original ECU.
Hondata no longer support OBD-0. WHAT to do. Which OBD-1 could suport this engine. Can we use from US civic 92-95 coupe non VTEC OBD-1 ECU from D15 engine?
We need to change the 1 wire O2 to 4 wire O2 sensor and Distributor.
Old Jan 25, 2005 | 03:58 AM
Padawan's Avatar
Darth ModerVader
http://www.turboedit.org/
Old Jan 25, 2005 | 05:55 AM
Wes V's Avatar
I'd highly recommend that you go to the PGMFI web site and read through the stuff there.
http://www.pgmfi.org
Wes
Old Jan 25, 2005 | 07:16 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">.AEM offers a competitive unit but reliability doesn't seem as good and idle quality is harder to achieve.
I have seen 3 hondata units fail so far this month, I have never seen an AEM unit fail.. All the cars that I tune with the AEM EMS idle perfectly, it just a matter or understanding what the idle parameters are and you can make it work perfectly..
Old Jan 25, 2005 | 12:24 PM
Root79's Avatar
Default Re: Interesting in Hondata. (tgreaves)
turboedit. This softvare for chip probraming?
In PGMFI are so many information, don't know where to start. Any way start to read from bening.
Thank's Guy's
Maybe somebody can explain the basics of chip tune.
Old Jan 25, 2005 | 12:31 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Root79 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe somebody can explain the basics of chip tune. </TD></TR></TABLE>
Not sure what you want to know here.. Thats kind of a broad question..
Old Jan 25, 2005 | 12:45 PM
Root79's Avatar
I'm going to buy the wideband lamda. To undertand the AFR process in ECU.
I can't decide how to start. I know the what kind of chips I can use in stock ECU. i can buy them here. What do I need to do next?
Old Jan 25, 2005 | 12:48 PM
tgreaves's Avatar
Understanding how air/fuel works and how ignition timing works and all that is the first step to tuning..
If you get your ecu socketed and buy the atmel 29c256 chips your also going to need a burner and the turboedit or uberdata software.. I would look at the software and get used to it..
Old Jan 25, 2005 | 12:57 PM
Root79's Avatar
Sorry, but what is burner?
Old Jan 25, 2005 | 12:58 PM
tgreaves's Avatar
Its how you put a map on a chip..
Old Jan 25, 2005 | 01:09 PM
Root79's Avatar
I think the chip selling company must have devices for that! I hope!
Old Jan 25, 2005 | 01:15 PM
Root79's Avatar
Turboedit only for OBD-0. Uberdat???
Old Jan 25, 2005 | 04:25 PM
Padawan's Avatar
Darth ModerVader
TurboEDIT is for OBD-0 ECU's and Uberdata is for OBD-1 ECU's.
Old Jan 25, 2005 | 11:40 PM
Root79's Avatar
I can create bin file for OBD-0 from Wideband lamda afr numbers? Recorded the wideband lamda data on special device. Like Inovate sell?
Old Jan 26, 2005 | 04:29 AM
Code Blue's Avatar
pm'ed
Old Jan 26, 2005 | 11:58 AM
Root79's Avatar
Default Re: Interesting in Hondata. (Code Blue)
Ok. I can use Turbo edit for OBD-0. But what about the chip. Tha same 29c256 for OBD-0?
Old Jan 26, 2005 | 12:02 PM
tgreaves's Avatar
Yep..
Old Jan 26, 2005 | 12:30 PM
Root79's Avatar
Thats greate. My friend rebuild the EF civic 1.5 mono to D16A6 turbo. I did the wiring for his car. He is ready to invest in manegment. Turbo edit and Atlem chip will work for his setup. He have brand new Garret 25 instaled. We use Nissan 200sx 375 injectors with resitor.
So, Turboedit+Atmel chip and Bosch Dyno I can help him?
Old Jan 26, 2005 | 11:21 PM
Root79's Avatar
I can make the BIN file with wideband lamda for turboedit program. I need sohc OBD-0 turbo map. Non VTEC. 1 wire Lamda.
