Wrong ECU causing trouble code?
Old Jan 22, 2005 | 09:53 PM
GWInquisitor14's Avatar
Default Wrong ECU causing trouble code?
I have an LS/VTEC b18b block w/ b16 head and a P30 ECU
Recently when im having fun w/ my car and reving higher, i will sometimes throw a trouble code. Its the first oxygen sensor. Would the P30 ECu be causing my engine to run a lil too lean and not putting enough fuel into it because it is meant for a 1.6 liter engine?
Old Jan 23, 2005 | 05:09 AM
Chiovnidca's Avatar
Default Re: Wrong ECU causing trouble code? (GWInquisitor14)
What code?
Old Jan 23, 2005 | 05:49 AM
JdmEKCivic's Avatar
Default Re: Wrong ECU causing trouble code? (Chiovnidca)
check the o2 with a ohnm meter, ive ran a couple of friend b16 motors with a p30 and they ran fine. b16/b18 should be no problem.
Old Jan 23, 2005 | 04:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">What code?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GWInquisitor14 &raquo;</TD></TR><TR><TD CLASS="quote"> i will sometimes throw a trouble code. Its the first oxygen sensor. </TD></TR></TABLE>
Old Jan 24, 2005 | 03:24 AM
Chiovnidca's Avatar
What's so hard about posting the code number? Here, i'll help. Is it 1, 41 or 43? Knowing this will greatly narrow down the troubleshooting.
Old Jan 25, 2005 | 07:37 PM
Its Number 1
I didn't realize there were a lot more codes than 1-23
I think i woulda gotten 45, Fuel system too rich or lean, if i was correct
thanx
nolicense526
Jun 27, 2007 07:02 PM
shraz
Aug 30, 2006 04:11 PM
1.8
Dec 15, 2004 07:14 PM
barry11j
Aug 3, 2004 03:07 PM
paybac4223
Jun 28, 2004 06:00 PM
