Exhaust spring bolt?
When looking for some of those bolts at my local honda dealer, the parts guy and I figured out that the bolts from the 93 accord are the same. I'm sure many others are as well, but that is for sure.
I've used mis-matched sets of spring bolts on my car from time to time. The actual length of the bolt is irrelivant to how it performs. As long as there is tension on the spring, and the nut is not loose, there should not be a problem. It is only there to absorb some of the 'shake' from the catback on the hangers, so it does not hurt the welds/studs on the exhaust manifold. Just find a bolt that threads and you're golden.
just swing by a local exhaust shop and buy a couple there.....probably cost you 2 bucks where at the dealer would probably cost you three times as much....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs »</TD></TR><TR><TD CLASS="quote">Try hardware store or home depot. All you really nead is a 90mm Length bolt grade 8- 12mm.</TD></TR></TABLE>
YUp....just remeber to use grade 8 bolts...i used grade 8 with a big washer to compress the spring...works the same way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fridexter »</TD></TR><TR><TD CLASS="quote">I assume 1 washer for each bolt is good, or 2?</TD></TR></TABLE>
one is good..make sure its grade 8 or else meltdown..literally
Zubz
Mar 30, 2003 09:07 PM
