Anyone who knows about building engines please help....
Hi there,
I just picked up a jdm d15b cheap which i'm going to build for boost. This is my first time. I want to take my time and pick up parts when they come up cheap. If i strip it back to the block and shove some rags in the intake ports and exhaust ports, how long can it stay like this without being detrimental to the engine? Say if i took two years before it was all back together. Will air and moisture destroy it? What can rust or will it be ok if its oil coated? Same question for the coolant paths and corrosion.
Thanks for any advice.
what i do when i save a engine is i soak it with wd40 and clear wrap it tight and put it on some 2x4 if its going in outside or in the garage and in a corner if its staying inside
B_Swapped93
Oct 24, 2013 04:32 AM
Erod
Oct 3, 2004 01:34 PM
