13" rims and GSR brakes Question...
I was wondering if it's possible to use a spacer(like one of those hubcentric things) to get a set of 13" stealies to clear GSR brakes......I have extrended wheel studs if that helps.....
The reason I'm asking this is a freind of mine is selling a set of 13" slicks on M/T rims for a very good price...I already have 20x6x14" slicks but I'm interested in trying out these 24/8R13 slicks...
Thanks in advance for your help
you can run 13's with a wicked off-set to clear the caliper on 10.2 rotors, might need to shave them down a little too. i'd imagine it would work with the right spacer, you'd have to bang the wells out and possibly cut fenders to get 24inchers in there if you stick them out that far though. 24's are pretty big diameter, you'll get tall gear outta that
Cool thx for the info, oh and I'll be using a spare set of banged up fenders to fit these tires...As far as the gear ratio goes, I'm looking into a 4.9 final drive gear set as we speak...
What offset would you recomend?
