Is there supposed to be a bolt here? (pics)
Old Jan 22, 2005 | 02:43 PM
litterbox's Avatar
I am a (Trial User) Army
Default Is there supposed to be a bolt here? (pics)
Hey,
I was under the car today because I noticed oil dripping. Anyway, is there supposed to be a bolt in this hole? It's on the driver's side of the transmission.
http://www.we-todd-did-racing....D.jpg
Thanks for your help
Old Jan 22, 2005 | 02:49 PM
kaiba's Avatar
Default Re: Is there supposed to be a bolt here? (litterbox)
It look like that were the stock header bracket suppose to bolt on.
Old Jan 22, 2005 | 03:09 PM
JDMH22HATCH's Avatar
Looks like the spot for the lower bracket the bolts to the tranny and the bottom of the block. Kinda like an L-shaped bracket. If that is what it is, then you don't need a bolt in there
Old Jan 22, 2005 | 03:23 PM
litterbox's Avatar
Default Re: Is there supposed to be a bolt here? (JDMH22HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH &raquo;</TD></TR><TR><TD CLASS="quote">Looks like the spot for the lower bracket the bolts to the tranny and the bottom of the block. Kinda like an L-shaped bracket. If that is what it is, then you don't need a bolt in there</TD></TR></TABLE>
Ok, my main concern is that I don't need to put a bolt in there.
Old Jan 22, 2005 | 03:26 PM
No, you don't need a bolt in there.
Old Jan 22, 2005 | 04:05 PM
Bond's Avatar
I would put one in just to keep junk out of it. Just in case you need it some time down the road.
Old Jan 22, 2005 | 04:18 PM
litterbox's Avatar
Default Re: Is there supposed to be a bolt here? (Bond)
Swap will come soon enough.
codenamezero
Welding / Fabrication
13
Feb 7, 2012 01:35 PM
theidealone
Nov 27, 2010 07:45 PM
117
16
Apr 2, 2009 10:18 PM
garylythgoe
Aug 1, 2006 11:56 AM
albert butterbikini
Jun 30, 2001 02:54 PM
