car just went into safe mode...
so i went for a quick spin around the block and i got a CEL, now there is a little red light in my ecu that is blinking (4 short) would this be a code 4? if so then thats the crank angle sensor, could this be my problem? how much on average is it to replace? thanks in advance guys!
i noticed that my distributor is making a wierd knocking sound, possibly related? i know my friend had to replace on in his EK awhile back. and when i take it to the shop which one should the shop order? i have a JDM gen 1 B16A, so would one for an DA GSR work? thanks
No you need an OBD0 B16a distributor which are tough to find...try http://www.distributorking.com
The DA GSR will not work because it is OBD1...A 90-91 integra will work but you will need to remoe one of the mounting legs for it to fit properly.
after a close examination i discovered that the previous owner only bolted down 2 of the 3 mounts and that it has two wires coming out of the top of it (black with yellow stripe, and blue) could this mean that he used a different dizzy? is it Obd0 or what? thanks for your help guys!
thats pretty much the sweetest mini van i have ever seen do you know where i can pick one up but it cant be green like lettuce cause lettuce pretty much makes me gag for sure. i need a new car cause i hit this curb really hard and a c230 beat me on the highway and it was pretty much the most embarassing thing ever but hit me back bra and i got a bike for sale if ya want it
KDvtec5757
10
Jul 23, 2009 06:07 PM
PrecisionH23a
Jul 22, 2002 09:23 PM
REDBARON
Jul 8, 2002 07:07 PM
