D15b water pump
More than likely its the z6 h20 pump. One other thing, why are you buying a water pump from Autozone? Unless you like swapping leaky pumps i'd stick to OEM Honda.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllmeGSR »</TD></TR><TR><TD CLASS="quote">so witch pump do i use? does any one know for sure
Is this the JDM D15B vtec? If so use the 92-95 VX water pump, not 100% sure, but its up in the 80s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control »</TD></TR><TR><TD CLASS="quote">i got mine from autozone says lifetime warranty .</TD></TR></TABLE>
Its probably limited lifetime warranty. Still good enough.
vx
type in search "d15b parts" and it gives alot of links to what parts to use
bottom end u use vx parts, timing belt, water pump, tensionser, cyl head u can use z6, dist, spark plugs, wires, valve cover gasket, etc etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pisetup »</TD></TR><TR><TD CLASS="quote">1994 Civic VX</TD></TR></TABLE>
apparently i was correct.
nasteawhun
11
Jul 21, 2008 02:19 PM
B18 CYA
12
Sep 3, 2006 08:27 AM
