Help me with my calcs and plot points on a compressor map! ASAP TIA
Old Jan 22, 2005 | 10:26 AM
shauniewalnuts's Avatar
Default Help me with my calcs and plot points on a compressor map! ASAP TIA
http://www.blackphoenixtech.co...t.xls
there is all the calculations i made in excel (took FOREVER!)
and here is the turbo map for the turbo i am thining of getting.
I am confused of how to plot the points on the Comp Map, do i adjust the PR to the rpm to get a slope?
Please tell me if all my calculations are correct and if this turbo is suitable
need your turbo smart people to give me a hand before i spend my $$ on the wrong ****! Thanks a million!!!
Old Jan 22, 2005 | 11:58 AM
Default Re: Help me with my calcs and plot points on a compressor map! ASAP TIA (shaun311)
bump!
Old Jan 22, 2005 | 04:03 PM
bummmmmmmmmmmmmmmmp
Old Jan 22, 2005 | 04:37 PM
Chiovnidca's Avatar
Old Jan 22, 2005 | 04:45 PM
Default Re: Help me with my calcs and plot points on a compressor map! ASAP TIA (Chiovnidca)
thanks for the bump!
Old Jan 22, 2005 | 05:31 PM
bump for a reggin
Old Jan 23, 2005 | 05:36 AM
bump
Old Jan 23, 2005 | 03:06 PM
eagles bump
Old Jan 23, 2005 | 05:19 PM
bump come on nobody knows this ****?????????????????
Old Jan 23, 2005 | 09:46 PM
bugster's Avatar
what are you trying to get out of this turbo. my computer cant use the link you have for some reason
looks to me like you can get bout 200ish hp with 9psi and bout 300ish hp with 20psi and still be in the effecient center
anyone else correct me if im wrong l
Modified by bugster at 11:50 PM 1/23/2005
Old Jan 24, 2005 | 07:30 AM
Buzzbomb's Avatar
I checked out your calc and it seems pretty close. The vertical scale is the Pressure Ratio, to you go up to 2.463 and draw a horizontal line, then on the bottom scale, go to 37 and draw a vertical line. Where they intersect is the efficency point the turbo is operating at at that boost level. You want the point to be in the high 70%'s
Modified by Buzzbomb at 11:40 AM 1/24/2005
Modified by Buzzbomb at 12:02 PM 1/24/2005
Old Jan 24, 2005 | 08:00 AM
Buzzbomb's Avatar
Default Re: Help me with my calcs and plot points on a compressor map! ASAP TIA (Buzzbomb)
To get a slope, adjust the RPM. Plot several (3 or 4) points. Usually you go 50% of redline, 75% of redline, and redline. This is where the turbo will be working the hardest. Again, you want to stay away from the surge line, (dotted) and stay in the highest efficiency as possible so you really aren't looking for a slope persay.
This turbo should / would good for you. B16 I assume? Try plotting the same numbers against other maps just for comparison and then make a decision.
Old Jan 24, 2005 | 08:37 AM
d16 mini me with z6 head.
i used other calcs and got lower numbers for both the PR and the air flow
using the following formulas...
(CID x RPM) / 3456 = CFM
CFM x VE = Corr. CFM
Corr. CFM x 0.069 = 11.81 lbs/min
(P1 + P2) / P2 = Pressure Ratio
what one do i go by?
Milab21
Dec 24, 2009 06:09 PM
Esprit09
Southeast (Sales)
Dec 6, 2009 05:27 PM
b18c1Monster
Nov 16, 2008 03:41 PM
shauniewalnuts
Jan 23, 2005 07:17 PM
BoostedJeff
Mar 29, 2004 06:39 PM
