b16a1 secondary o2 elimination
sorry search did not work but can somone please tell me how to eliminate the secondary o2 sensor on a b16a1. also why is there 2 of them? i am using a pr3 ecu and it is a 89 crx hf
Do you mean a b16 sir1..? Because I dont think theres a b16a1..
And there's suppose to be 2 of them..If you want to get rid of it then switch to obd1 and get one 4 wire 02..
Obd0 is 2 o2 sensors..
obd1 is 1..
obd2 is 2..
obd1 is 1..
obd2 is 2..
Get a chip that elimates the secondary sensor or you might try your luck in splicing the o2 wires together. Sometimes it works good and sometimes not. Im looking for a good chip for my b16 right now that gets rid of the 02 sensors (or at least 1) but cant seem to find a good one.
This is what I am doing...but It's due to the AN-R header I just bought.
4-Wire o2 sensor split into the ecu. Let's hope it works well. BTW I am running pw0.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer »</TD></TR><TR><TD CLASS="quote">yeah and the b16a1 was the euro version correct me if im wrong</TD></TR></TABLE>
I thought the A5 was the euro version.
if you want to run just one o2 sensor the best thing to do would be to find a program like uberdata or ghettodyno or something along those lines becuase they have settings that can actually eliminate sensors. if u install this program into your ecu, all you have to do is cancel out the second one and youll be straight
lol yeah it is,if you run just one without doing anything,2 cylinders will run rich,and 2 will run lean.....get something to either run both or get a program that elimates one
cmdeoro
Engine Management and Tuning
17
Jul 29, 2009 08:00 AM
