(SEARCHED) POST PICS OF POLISHED VX/HX RIMS
Guest
Posts: n/a
I have a set of hx rims, and i have seen it in the past some DIY polished hx rims, looked pretty sick, wanting to do it myslef, but cant find any info on doing it, if anyone know how to do it, please post pics or links, or a FAQ would be nice
thanks in Advanced
Modified by sohcvtec66 at 7:55 PM 1/27/2005
Modified by sohcvtec66 at 8:08 PM 1/27/2005
thanks in Advanced
my friend used aircraft remover to remove the finish. then once its down to the bare metal, he wet sanded it with like 600 grit. wet sanded some more, and then some more, and then some more. and finally he used some metal polish on them.
Dam, in full polish mode, they actually don't look so small anymore. That white eg is hot.
heres a diy
https://honda-tech.com/zerothread?id=804963
heres a diy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">
not bad...not bad at all....now go sand some more
btw...hows bout some pics on da EK....
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mulletov »</TD></TR><TR><TD CLASS="quote">Dam, in full polish mode, they actually don't look so small anymore. That white eg is hot.
heres a diy
https://honda-tech.com/zerothread?id=804963</TD></TR></TABLE>
Hey thanks man, yeah as we speech the rims are drying with the aircraft disolver stuff, it really eats it off, make sure you really goop it all over the rim, i am using 400 grind, cuss i get tired of sanding, but i sanded a bit off the lip, and i can already see the bling (exited)
, next step will be sanding fun...lol
i bought aircraft eater ****
400 grit fine, wet paper,
mothers chrome polish, and some sos pads, when i am done illl have my buddy link up pics,
Thanks for everyone help
heres a diy
, next step will be sanding fun...loli bought aircraft eater ****
Guest
Posts: n/a
Guest
Posts: n/a
I finally got most of the painted finish off, i recommend useing a paint brucsh or a wash pad, and bouch it , now i will start sanding them down, then once i get to all aluminum, ill use a lighter grit paper, then a lil anetone, then i will be using mothers chrome cream, then buff
