Seat belt light/chime
Old Jan 21, 2005 | 06:56 PM
AllmeGSR's Avatar
Default Seat belt light/chime
Ok well i got this 91 Si. The inside was spray painted so they screwed around a lil with ii but the wiring is great. The problem is the seat belt chime stays on all the time, what would cause this and what can i do to fix or stop the chime for now till i can fix the problem. Its buging the **** out of me.
Old Jan 21, 2005 | 07:03 PM
CRXDrew's Avatar
take out the cover plate where the two lil seat belt lights are... then just unplug the harness. I just unplugged it permanently.
Old Jan 21, 2005 | 07:32 PM
AllmeGSR's Avatar
Default Re: (CRXDrew)
It does it even when the seats are unpluged from under the butt ban, if thats what your talking about.
Old Jan 21, 2005 | 08:30 PM
honda06si's Avatar
Default Re: (AllmeGSR)
sorry to post jack but my plugs are plugged in and my seat belt light doesnt come on and it doesnt chime so how do i fix that???
Old Jan 21, 2005 | 09:48 PM
31flavorscivic's Avatar
Default Re: (honda90si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew &raquo;</TD></TR><TR><TD CLASS="quote">take out the cover plate where the two lil seat belt lights are... then just unplug the harness. I just unplugged it permanently. </TD></TR></TABLE>
That's what I did. It's pretty obvious if you + passenger are wearing seat belt or not, and mine was door activated, it was bizarre. Had to click ignition off/on quickly for a while before I just said screw it and yanked the damn thing.
Old Jan 22, 2005 | 06:26 PM
honda06si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda90si &raquo;</TD></TR><TR><TD CLASS="quote">sorry to post jack but my plugs are plugged in and my seat belt light doesnt come on and it doesnt chime so how do i fix that??? </TD></TR></TABLE>
Old Jan 22, 2005 | 06:50 PM
CRXDrew's Avatar
Did you do what I said? Did you even look at the overhead assembly. Once you remove the plug the chime will go off. No power = no chime.
And for honda90si, check the fuses first. Then check the plug that connects to the bottom of ur seat belt latch assembly.
Old Jan 22, 2005 | 07:40 PM
honda06si's Avatar
fuse is good and plugs are plugged in...maybe i need to replace those lights? where would i get new ones?
Old Jan 24, 2005 | 08:27 AM
honda06si's Avatar
Old Jan 24, 2005 | 12:49 PM
JohnnieChimpo's Avatar
How can this be unhooked from a CRX?
deving916
68
Mar 28, 2012 04:23 PM
lilvietboy
May 21, 2009 08:30 PM
fastball777
Jun 23, 2004 12:52 PM
haophat
Mar 12, 2004 11:23 PM
erikiksaz1
10
Dec 22, 2003 11:20 PM
