F22 v-tec swap
Old Jan 21, 2005 | 04:22 PM
dazn's Avatar
Default F22 v-tec swap
what ecu and harness do I use? what wire splicing/swapping do I need to do? has anyone successfully done this swap on this forum? DON"T TELL ME TO JUST DO A H22!
Old Jan 25, 2005 | 02:07 PM
98civicdude's Avatar
Default Re: F22 v-tec swap (dazn)
go to a junk yard and try to find the engine harness and ecu out of an accord. i believe the f22 sohc vtec engines (f22b1) came out of the 94-97 accord ex's. or you could try ordering those parts. otherwise im not sure what other harnesses and ecus are compatible.
Old Jan 25, 2005 | 02:09 PM
Default Re: F22 v-tec swap (98civicdude)
if you could get the engine harness from the car that you got your engine from, and also ecu, just plug it right up. what car are you putting it in anyways? a civic? it would have to depend on what year your car is also. obd reason. you might need to buy a obd conversion harness.
Bobbyboyd
Honda Civic (2001 - 2005)
Sep 17, 2016 01:35 AM
stunin92_accord
Dec 7, 2010 08:18 AM
PaChiLa Leader
Nov 8, 2008 10:52 PM
omarisramo
Aug 5, 2008 01:45 PM
mcgee*
May 23, 2006 08:43 AM
