Are All 94-01 Integra Clusters The Same ???
are all the 94-01 Integra GSR Gauge Clusters the same??? because i needed a new underdash harness that connects to the gauge cluster...clock..cig lighter..etc etc...and one guy sent me a underdash harness he said was for a 94-01 Integra GSR...and when i recieved it i looked at the harness and there wasnt enough plugs for the back of the cluster.... there was only 2 baby blue plugs and one yellow instead of there being 3 baby blue ones and one yellow.... here is how the back of my GSR Cluster looks like
As you can see theres 4 outlets for the plugs
And this is the harness i recieved
Is it just me or did i recieve the wrong harness or what???
im confused
im confused
looks to me that the tiny blue plug is the Service Connector so you can pull codes. Its the full dash wiring harness by the looks of it. that larger blue plug right below it along with the gray plug into the ECU. It is also possible he gave you an AUTO harness.
dammit ive been searching for soo long like 5 weeks for this one part....see my harness was cut right after the 4 plugs in the back of the cluster turns into one wire...and i just want to get another harness so i can have my cluster working...and its like impossible
i think those blue plugs with the 1 yellow may plug into the passenger airbag or something. im all thrown off, but for sure those plugs aint goin in the back of that cluster. and your avatar is bad ***!
na na it goes to the cluster those 2 blue plugs and one small yellow one i circled plugs into the cluster...im just saying there is another baby blue plug that is missing that goes into one of the outlets on the back of cluster
and one guy told me
" the ones circled in red are what u use to connect to the cluster, not the little blue one
its only 3 plugs man ur straight
one of the outlets u don't use "
so whats up with that??? and thanks about the atavar shes bad
Modified by Got Milk at 12:06 PM 1/22/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecdc4 »</TD></TR><TR><TD CLASS="quote">94-95 and 96-01 dash harness is different.
the gauge cluster plugs are different.</TD></TR></TABLE>
This sounds right, since 96+ is OBD2.
Wrong! The plugs are the same, a couple of the wires are switched.
the wiring is different period. 94-95 is compatible and 96-01 is compatible. It has to do with the OBD1 to OBD2
there are ways around it. the easiest is to just take the gauges out of one and thow them into the other. the 94-01 gauges will work in any cluster from 94-01.
so in conclusion guys am i going to be able to install this harness and only plug in 2 baby blue plugs and one small yellow one ? and leave that one outlet in the back of the cluster without a plug ?
litterbox
13
Feb 12, 2005 06:05 AM
Got Milk
Jan 21, 2005 06:30 PM
