EK Power Door Lock Conversion
Old Jan 21, 2005 | 01:36 PM
JDM B16 EK's Avatar
Default EK Power Door Lock Conversion
i have already tried searching for threads on this topic but couldn't seem to find what i needed. i have a 96 dx hatch with si doors which i bought like that and don't know what the seller did with the power locks because they're not there as my alarm installer tells me . i've been trying to figure out what is needed for this conversion first i thought all i need was the actuators, then i find out i need a module, and harnesse(s), and a floor harness. can someone please tell me everything i need and how to do the conversion please
TIA
Old Jan 21, 2005 | 02:31 PM
JDM B16 EK's Avatar
Default Re: EK Power Door Lock Conversion (JDM B16 EK)
TTT
Old Jan 21, 2005 | 03:53 PM
hatchi's Avatar
you will need actuators and door lock module which is like a relay if you are using stock switches. if you already did the power window setup you would most likely have the floor harness already
Old Jan 21, 2005 | 04:40 PM
2lua's Avatar
try to do some search.
http://repo.jackmoves.com/album206
http://info.honda-tech.com/index.info/Main_Page
Old Jan 21, 2005 | 08:26 PM
JDM B16 EK's Avatar
Default Re: (2lua)
thanks for you help again guys. i'm just gettin really confused cuz i people keep telling me i need more and more stuff just want to know for sure before i start buying stuff.
is this the modlue?
Old Jan 22, 2005 | 01:16 PM
JDM B16 EK's Avatar
Default Re: (JDM B16 EK)
TTT
Old Jan 22, 2005 | 03:14 PM
Boosted96EK's Avatar
I did it in my car... check out my lil write up in my sig...
Old Jan 22, 2005 | 04:07 PM
Smith Wise's Avatar
Default Re: (Boosted96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted96EK &raquo;</TD></TR><TR><TD CLASS="quote">I did it in my car... check out my lil write up in my sig...</TD></TR></TABLE>
good job
you should do an "official H-T FAQ" write-up
Old Jan 22, 2005 | 04:14 PM
2lua's Avatar
that's it.
Old Jan 22, 2005 | 06:20 PM
JDM B16 EK's Avatar
Default Re: (2lua)
thanks
Old Jan 23, 2005 | 01:58 AM
JDM B16 EK's Avatar
so all that is needed is the actuators, module, and the floor harness?
Old Jan 23, 2005 | 05:19 AM
2lua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16 EK &raquo;</TD></TR><TR><TD CLASS="quote">so all that is needed is the actuators, module, and the floor harness?</TD></TR></TABLE> right, but you don't really need the floor harness. you can make the harness yourself.
Old Jan 23, 2005 | 06:47 PM
JDM B16 EK's Avatar
Default Re: (2lua)
cool........now any body with a module they want to sell me?
Old Jan 26, 2005 | 01:22 PM
JDM B16 EK's Avatar
so i'm still a little confused i need to know EXACTLY what i need so far i know i need:
Actuators
Module (rely)
Door harness (do i need 1 or 2? one just one for driver side or 2 for both?)
and floor harness (would i need this if i already have my power windowns hooked up?)
is there anything else i need or should do? its going in my 96 dx hatch w/SI doors with working power windows
TIA
Old Jan 26, 2005 | 08:11 PM
JDM B16 EK's Avatar
can anyone help me?
Old Jan 26, 2005 | 08:32 PM
ErrDizzle's Avatar
i believe 96-98 floor harnesses and 99-00 floor harnesses are different.
so 96-98 cars have to use EX parts and 99-00 cars can use either SI or EX parts
Old Jan 27, 2005 | 02:20 PM
JDM B16 EK's Avatar
Default Re: (a_kaibigan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a_kaibigan &raquo;</TD></TR><TR><TD CLASS="quote">i believe 96-98 floor harnesses and 99-00 floor harnesses are different.
so 96-98 cars have to use EX parts and 99-00 cars can use either SI or EX parts</TD></TR></TABLE>
yea i've heard this too. but don't know what to do because my car is a 96 DX with 99-00 si doors.
the 96-98 modles have the door lock modules in the driver side door while the 99-00 have them in the kick pannel in near the foot rest.
so i don't know what module and harness i need to get to get it to work
Old Jan 27, 2005 | 10:06 PM
JDM B16 EK's Avatar
can anyone help me please!!! never though this conversion would be such a bitch
Old Jan 27, 2005 | 10:31 PM
soundbomber's Avatar
your alarm installer should be able to sell you some door lock solenoids and wire it up to the stock switch as well as your alarm, and a much cheaper price than the honda ones, and just as good
Old Jan 27, 2005 | 10:47 PM
JDM B16 EK's Avatar
Default Re: (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">your alarm installer should be able to sell you some door lock solenoids and wire it up to the stock switch as well as your alarm, and a much cheaper price than the honda ones, and just as good</TD></TR></TABLE>
yea i'm thinking about calling it quits and doing that. because this is taking to much work eventhough OEM ones would be nice
Old Jan 27, 2005 | 11:38 PM
ErrDizzle's Avatar
I dont suggest getting aftermarket door actuators. they are loud as ****. the OEM ones are much nicer. If you ONLY want power door locks just get the actuators and switch. wire those and forget about the factory wiring
Old Jan 28, 2005 | 01:06 AM
BuddhaSiR's Avatar
You guys make it seem like its hard as hell. You already have the door with the power locks/windows. The lock is apart of the latch. you just have to wire your alarm to it. that's the way my 98 hatch is done.
Old Jan 28, 2005 | 04:24 AM
monicle's Avatar
Default Re: (BuddhaSiR)
if you want a clean install then get the floor harness from a 99-00 si or ex or hx coupe. those 3 came with power windows mirrors and locks and will be a direct swap into your car. you alreay have everything inside the doors I assume so youre just going to need the floor harness and the lock module which you posted earlier. other than that you will need the power window relay, some 20 amp fuses and thats it.
Old Jan 28, 2005 | 01:19 PM
JDM B16 EK's Avatar
Default Re: (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a_kaibigan &raquo;</TD></TR><TR><TD CLASS="quote">I dont suggest getting aftermarket door actuators. they are loud as ****. the OEM ones are much nicer. If you ONLY want power door locks just get the actuators and switch. wire those and forget about the factory wiring</TD></TR></TABLE>
i don't want to have to get the aftermarkets either. i already have power windowns with the switch for the locks, i just need power locks. I also just orded a pair of actuators. i can wire this up to my alarm without the door lock module and floor harness? if so can you tell me how please.
Old Jan 30, 2005 | 02:00 AM
JDM B16 EK's Avatar
TTT
