How do you replace motor mount inserts?
Old Jan 21, 2005 | 01:00 PM
rocketfuelcerx's Avatar
Default How do you replace motor mount inserts?
Do You cut out the old one and install the new with some type of adhesive?
Old Jan 21, 2005 | 01:09 PM
dantastic's Avatar
Default Re: How do you replace motor mount inserts? (rocketfuelcerx)
just take the old ones out and put the new ones in. it couldnt be easier
Old Jan 21, 2005 | 01:11 PM
NonovUrbizniz's Avatar
Loved
Just for clarification...
Motor mount inserts are just that... they insert over the stock mounts... unless you previously installed inserts yourself you don't remove ANYTHING...
they just slip in on either side of the stock mounts... then you use zipties (generally supplied with the mounts) to hold them in place... although they (the zip ties aren't really needed as the mounts will hold them in place once re-installed.)
Old Jan 21, 2005 | 01:12 PM
chris_c's Avatar
Default Re: How do you replace motor mount inserts? (dantastic)
i am not sure what you are asking. a motor mount insert is to be used with a good motor mount. the fit in like puzzle pieces and make the mount stiffer. you undo the mount, slip the inserts in and bolt it back up.
your question seems worded like you want to replace the OE mounts rubber with the inserts you bought. you can't do that.
Old Jan 21, 2005 | 01:23 PM
beerbongskickass's Avatar
Default Re: How do you replace motor mount inserts? (chris c)
http://www.jimfab.com
I got all 3 lower mounts for $110 shipped. My motor is rock solid and they eliminated my wheel hop.
importfanatic17
Feb 14, 2007 04:30 PM
91crxturbo
Jan 10, 2007 08:03 PM
Novtecdohc
Jun 24, 2005 01:16 PM
rocketfuelcerx
Apr 8, 2005 11:53 AM
Muckman
Aug 28, 2002 12:18 AM
