Question on compression and air/fuel ratio.
Old Jan 21, 2005 | 12:28 PM
litterbox's Avatar
I am a (Trial User) Army
Default Question on compression and air/fuel ratio.
Hey,
If you've been tuned for an 11.1 CR but then you rebuild your engine and you bump up your CR to 12.5 and your tuning remains the same for the time being, will you run richer/leaner? An explanation would be great.
Thanks,
George
Old Jan 21, 2005 | 12:40 PM
dantastic's Avatar
Default Re: Question on compression and air/fuel ratio. (litterbox)
a/f should stay the same. the only time a/f changes is if you change the fuel curve or the way air enters the motor
Old Jan 21, 2005 | 01:04 PM
jr_istheman's Avatar
Default Re: Question on compression and air/fuel ratio. (dantastic)
when adding an exhaust (from a 2.25 to 2.5+ hiflow cat) to a setup tuned to run on that current ECU, does that make it run richer or leaner?
chris_c's Avatar
12.5:1 WOW!
11:1 to 12.5:1 is a big jump. what exactly are you changing? i can't even see camshafts happy in an 11:1 engine being happy in a 12.5:1 engine.
i'd get it tuned again, but i see the $ of tuning cheap insurance to protect expensive parts.
Old Jan 21, 2005 | 01:07 PM
NonovUrbizniz's Avatar
Loved
at that high compression cam/ignition timing is more important than fuel...
You could detonate a perfect mix if the ignition isn't firing it off fast enough.
Old Jan 21, 2005 | 01:29 PM
litterbox's Avatar
Default Re: Question on compression and air/fuel ratio. (NonovUrbizniz)
What type of ignition upgrade would you recommend?
Old Jan 21, 2005 | 09:43 PM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">a/f should stay the same. the only time a/f changes is if you change the fuel curve or the way air enters the motor</TD></TR></TABLE>
So air exiting the motor wouldn't affect the a/f ratio if it was changed to, let's say:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jr_istheman &raquo;</TD></TR><TR><TD CLASS="quote">when adding an exhaust (from a 2.25 to 2.5+ hiflow cat) to a setup tuned to run on that current ECU, does that make it run richer or leaner?</TD></TR></TABLE>
Old Jan 21, 2005 | 10:20 PM
eK9aT10pSi's Avatar
get the MSD 6A
Old Jan 21, 2005 | 10:21 PM
eK9aT10pSi's Avatar
it should lean it out a bit. same with boost, raise the psi, raise the fuel psi
Old Jan 22, 2005 | 07:08 AM
tthomass's Avatar
Default Re: Question on compression and air/fuel ratio. (eK9aT10pSi)
12.5........on what?
Old Jan 22, 2005 | 03:07 PM
litterbox's Avatar
Default Re: Question on compression and air/fuel ratio. (tthomass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthomass &raquo;</TD></TR><TR><TD CLASS="quote">12.5........on what?</TD></TR></TABLE>
JR's car.
Old Jan 22, 2005 | 09:50 PM
on b20/vtec TODA cams
Old Jan 22, 2005 | 09:54 PM
litterbox's Avatar
Default Re: Question on compression and air/fuel ratio. (jr_istheman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jr_istheman &raquo;</TD></TR><TR><TD CLASS="quote">on b20/vtec TODA cams</TD></TR></TABLE>
O snap!
Old Jan 25, 2005 | 11:48 AM
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">
The o2 sensor should adjust for any lean conditions...
IE if it does lean out the o2 should compensate by fueling more creating a stoich mix.
I'd also recomend the msd 6a
Old Feb 2, 2005 | 02:51 AM
clayne's Avatar
Not at WOT it won't be. I'd never rely on a stock O2 sensor anyways.
evilpenguinking
Jan 11, 2013 07:06 AM
Rocket
Jun 16, 2005 09:21 PM
litterbox
Feb 9, 2005 12:43 PM
xonn
Mar 5, 2003 10:02 AM
downpipe
Feb 1, 2002 10:30 AM
