Dsport magazine says 11 whp with the direct hits spark plug setup...
Old Jan 21, 2005 | 12:26 PM
pane93civhb's Avatar
Default Dsport magazine says 11 whp with the direct hits spark plug setup...
i read this in the magazine thought it was pretty tight .. but they tested it on a turbo car that already had msd. ignition on it and what not.. they took that stuff off of it and re dyno'ed it and it came out to be around 11 horsepower.. to the wheels i thought that was tight.. and the whole kit is only a lil under 200 bucks.. has anyone tested this or used it .. at all one of my frineds has it but he is not sure.. he only has an ls swap with intake headers and exhaust and the direct hits system as well.
Old Jan 21, 2005 | 12:54 PM
Turbo E's Avatar
Default Re: Dsport magazine says 11 whp with the direct hits spark plug setup... (pane93civhb)
i hope they used the same plugs for testing...or at the very least used new plugs for their baseline test.
in general I'd say it prolly bunk.
Old Jan 21, 2005 | 12:58 PM
HatchEh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb &raquo;</TD></TR><TR><TD CLASS="quote">i read this in the magazine thought it was pretty tight .. but they tested it on a turbo car that already had msd. ignition on it and what not.. they took that stuff off of it and re dyno'ed it and it came out to be around 11 horsepower.. to the wheels i thought that was tight.. and the whole kit is only a lil under 200 bucks.. has anyone tested this or used it .. at all one of my frineds has it but he is not sure.. he only has an ls swap with intake headers and exhaust and the direct hits system as well. </TD></TR></TABLE>
I'd like to know more about this... sounds interesting.
Old Jan 21, 2005 | 01:25 PM
beerbongskickass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb &raquo;</TD></TR><TR><TD CLASS="quote">i read this in the magazine</TD></TR></TABLE>
Stop reading magazines...
Old Jan 21, 2005 | 01:38 PM
flood's Avatar
Default Re: Dsport magazine says 11 whp with the direct hits spark plug setup... (beerbongskickass)
Um, unless the MSD system wasn't working properly I find an 11hp increase extremely unlikey.
Old Jan 21, 2005 | 01:48 PM
Turbo E's Avatar
i read in a magazine there were pills to make my weiner longer...must be true...they wouldn't lie to me would they?
Old Jan 21, 2005 | 02:00 PM
CivicSiR's Avatar
Default Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">i read in a magazine there were pills to make my weiner longer...must be true...they wouldn't lie to me would they? </TD></TR></TABLE>
its true man, i used some, and then i pulled mad hoes....i now have a 10 inch ****
Old Jan 21, 2005 | 02:04 PM
berettagtz117's Avatar
LMFAO..
Old Jan 21, 2005 | 04:15 PM
Em1guy's Avatar
Default Re: Dsport magazine says 11 whp with the direct hits spark plug setup... (flood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote">Um, unless the MSD system wasn't working properly I find an 11hp increase extremely unlikey. </TD></TR></TABLE>
the car was turbo its realistic na wil be less!
Old Jan 21, 2005 | 05:34 PM
zRd#1's Avatar
Default Re: Dsport magazine says 11 whp with the direct hits spark plug setup... (Em1guy)
Just to straighten out the facts here...
The car is a 1991 Civic with B16a and DRAG turbo kit.
The car had MSD SPARK PLUG WIRES NOT IGNITION!
The EF also had a new set of NGK spark plugs.
Then the Direct Hits system was installed complete with spark plugs and dyno'ed.
Gains were recorded at 11 whp.
Dyno graphs are in the magazine to prove it.
Pick up a copy and check it out for yourselfs.
Old Jan 21, 2005 | 05:37 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: Dsport magazine says 11 whp with the direct hits spark plug setup... (zRd#1)
magazine racers. ?
Old Jan 21, 2005 | 06:44 PM
here is the dyno chart and the magazine is article starts on page 36 and ends on page 38.....
here is the frst page with the article about the direct hits...
and here is a lil closer look at the improvement of the car mostly happend in vtec though when it engaged it gave more power.. so maybe its not just the Turbo car that made it improve maybe it had something to do with the vtec they said they will test it on more cars though..
Modified by pane93civhb at 8:52 AM 1/22/2005
Old Jan 21, 2005 | 08:14 PM
714phil's Avatar
I am in no way trying to sell any product here. I was also skeptical when i saw this system claiming it would make horsepower. I pretty much thought when i switched over to direct hits, it would yield no results in the horsepower department. Let me give you a little more detail on what happened.
Here are the details.
stock b16a w/ a drag gen 3 turbo kit. Ignition system consisted of NEW NGK BKR7E's with fairly new MSD wires. NO MSD IGNITION SYSTEM WAS USED.
I did 3 dyno pulls. 1 cold run let it cool down for about 5 minutes, then did 2 back to back. Peak horsepower out of the three runs were 226whp.
Then i installed the direct hits system which consisted of their own spark plugs which was a little bit hotter of a plug than the BKR7E's.
Then i did another 3 dyno pulls. 1 cold run let it cool down for about 5 minutes, then did 2 back to back. Peak horsepower with the direct hits system was 238whp.
Believe it or not, it made 11whp on my car.. i did all of the work/dyno myself and saw the gains with my own eyes. If anyone has any questions, feel free to ask.
Phil.
Old Jan 21, 2005 | 08:24 PM
CRXified's Avatar
Default Re: Dsport magazine says 11 whp with the direct hits spark plug setup... (STD ONEpointSIX)
cool they sound like a "nice hit"
Old Jan 21, 2005 | 09:20 PM
eK9aT10pSi's Avatar
some more details ...
what company ?
parts needed to be replaced/installed ?
comments about the power thorugh the powerband ?
thanks
Old Jan 21, 2005 | 10:04 PM
vg7z's Avatar
id trust Dsport...their magazine is all go no show all the ads in their mag are reputable companies with products that work unlike import tuner all u see is neon 50 cent and other BS
Old Jan 21, 2005 | 10:09 PM
trustnoone7935's Avatar
Default Re: Dsport magazine says 11 whp with the direct hits spark plug setup... (syntax_error)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax_error &raquo;</TD></TR><TR><TD CLASS="quote">magazine racers. ?</TD></TR></TABLE>
everyone has a printer,i don't trust it unless i've seen it in person
Old Jan 21, 2005 | 10:30 PM
Resident Evo's Avatar
Default Re: (vg7z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vg7z &raquo;</TD></TR><TR><TD CLASS="quote">id trust Dsport...their magazine is all go no show all the ads in their mag are reputable companies with products that work unlike import tuner all u see is neon 50 cent and other BS</TD></TR></TABLE>
I can agree too. The car they feature are all top notch. Plus I seen a lot of awesome cars at the shops.
Old Jan 21, 2005 | 11:14 PM
Default Re: (EBP-Si)
I think that this dude.. (STD ONEpointSIX) MUST BE THE ONE IN THE MAGIZINE..maybe that would be weird if he was he has links to there site.. if u doubt what i say go to the store dont buy the magazine but read the article i just that it was an interesting topic and a cheap way to bring a bunch of power to ur cars so take it for what it is.
Old Jan 22, 2005 | 07:44 AM
Default Re: (pane93civhb)
bump//// for a topic that i think is cool.
Old Jan 22, 2005 | 08:45 AM
hb_guy's Avatar
link? website? i'm curious and bored
Old Jan 22, 2005 | 09:06 AM
NathanMorris's Avatar
Default Re: (hb_guy)
[nm]
Old Jan 22, 2005 | 09:23 AM
Sean Juan's Avatar
Default Re: (92Lx)
wouldnt hurt to try and see what they do... where can u get them?
Old Jan 22, 2005 | 09:27 AM
nsxmatt's Avatar
Is that a coil on plug setup and does it replace the ignitor and coil in the distributor?
Old Jan 22, 2005 | 09:34 AM
FWejCOUPE's Avatar
Default Re: (nsxmatt)
any info on this stuff
