OT: What's the largest wrench I would need to work on my R
Since I had an issue with not having the right size tools, I plan on buying so open ended wrenchs and some more deep sockets. Just need some sizes to aim for.
[Modified by ITR 1413, 1:31 PM 1/12/2002]
Largest socket you'd need would be a 32mm for the axle nut.
We broke a heavy duty Snap On ratchet.
8 10 12 14 17 19 22 24 32 and i would get doubles of these 12 14
or you could just get the gator grip thingy on TV for 19.95 J/K
[Modified by Ayanami, 4:18 AM 1/13/2002]
ok, im stumped.
only thing i can think of is if your using aftermarket fuel lines or something, and have a real small hose clamp.
Bone, I'm stumped. I don't know where a 7mm is. I know where a 13mm is, if anyone cares to guess.
Also, does anyone know where a 7/8" wrench is used?
did you try punching out that notch in the axle nut ?
if your jumping on it and its not un notched , youll **** it up .
also, don't forget a 7mm.
It is used on the engine.
You know where?
You know where?
bling!bling!
header spring bolts are 12/14
rod bolts are 13mm.
arp head studs are standard 1/2" 12pt.
sometimes the ac adjuster bolt is a 10mm
you wont mess up the axle or nut if you dont remove the dimple.
I use a 6' bar on the breaker bar to get it off either that or my impact.
me + breaker bar + 6' pipe = 600lbft torque!!!
rod bolts are 13mm.
it is on the TB, only needed if you wanna adjust the TG+B blade opening. It is the one stated "NOT TO MEES WITH!" in the helms.
removing the head studs! also the only damn 12 point socket ill ever use.
