Crunchy Reverse
Old Jan 21, 2005 | 10:10 AM
BloodPressure's Avatar
Default Crunchy Reverse
I just bought a 95 del sol si 5spd. Reverse seems to grind a bit, do you think that could be due to the fact i may need a new clucth?
Thanks,
Old Jan 21, 2005 | 10:13 AM
Ricey McRicerton's Avatar
Default Re: Crunchy Reverse (BloodPressure)
Yes, it could. Have you tried putting the car in 2nd and then reverse?
Old Jan 21, 2005 | 11:11 AM
m3dia_lab's Avatar
actually, if you shift into any foward gear then shift to reverse it will be fine. i use 3rd then shift to reverse....
seems to common with most honda's...?
Old Jan 21, 2005 | 11:16 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (m3dia_lab)
yep and some domestics also like to be shifted into a forward gear before going into reverse because reverse gears aren't synchronized so shifting into a forward gear helps to eliminate the grind before going into reverse.
Old Jan 21, 2005 | 11:21 AM
integraXTC's Avatar
yup, happens to me alot. Finally figured to put it in fwd gear first and not push all the way far right, b4 putting it in reverse. I usually use 2nd gear.
Old Jan 21, 2005 | 11:22 AM
eJone powereD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m3dia_lab &raquo;</TD></TR><TR><TD CLASS="quote">actually, if you shift into any foward gear then shift to reverse it will be fine. i use 3rd then shift to reverse....
seems to common with most honda's...?</TD></TR></TABLE>
i do the same...putting it into a forward gear first would work most of the time
Old Jan 21, 2005 | 11:49 AM
Zak8022's Avatar
yep... as the others have already stated.
i've heard of this happening on alot of honda trannys. every one i've driven has done it, and is always remidied by the methods described above.
Old Jan 21, 2005 | 11:57 AM
Kyles ej1's Avatar
Default Re: (Zak8022)
i use 4th then reverse
Old Jan 21, 2005 | 07:16 PM
pancake56's Avatar
Default Re: (93blkej1)
this is a problem with all manuals. its always recomended to step on the clutch for a few seconds before shifting into reverse or you can shift forward into any gear. its not a clutch problem.
snee
Oct 6, 2017 07:52 PM
Soltis
Acura TL, RL & ZDX
May 26, 2010 08:56 PM
eMpAtHy
Jan 22, 2009 10:42 AM
Understeer
Nov 5, 2002 09:33 AM
