spark plug wire
Old Jan 12, 2002 | 11:26 AM
Ignitecivic's Avatar
Default spark plug wire
just adding an Megnecor spark plug wire, will it do anything.
Old Jan 12, 2002 | 11:27 AM
DragII's Avatar
25 Year Member
Default Re: spark plug wire (Ignitecivic)
nope.
stick w/ stock
Old Jan 12, 2002 | 05:19 PM
deepnite's Avatar
they might look cool and u can brag it too..but to get all u can get out of them...upgrade ur ingition, coil and distributor cap
Old Jan 12, 2002 | 05:26 PM
GSRaCeRbOI's Avatar
nope wont do anything unless your stock wires were bad/worn in the first place... stick w/ stock unless you have FI, in that case you should get an ignition kit also
i had a set of magnecors for sum reason spark plug wire #2 kept popping off the spark plug.. i sent it back for warranty and they said nothing was wrong w/ it.. mysteriously (not really) when i put back my stock wires.. nothing has happened..
anyone know how to fix/remedy the magnecor wire that pops off the plug when driving? (leads to stumbling and CE light).. i tried crimping it kinda but maybe i didnt do it right.. it still popped off... no problems after i said F*$% using the magnecors and switched back to stock..
spens 91 Ef
Feb 10, 2009 01:31 PM
hondaeg8
11
Jul 29, 2004 10:37 PM
