Front rotor size 96-00...
Old Jan 21, 2005 | 07:34 AM
_Cyclone_'s Avatar
Default Front rotor size 96-00...
Okay, I know the 96-00 EX models have 10.3" front rotors. This is my dillema... My 1997 Acura 1.6EL should have the same 10.3" front rotors/calipers/knuckle as the 96-00 Civic EX because it's essentially the same car. I bought a steering knuckle from the pick and pull from a 1997 Civic EX, and the caliper mounting holes didn't line up. Are my EL's front rotors larger than the EX's 10.3? No ABS by the way...
Old Jan 21, 2005 | 08:13 AM
pdiggitydogg's Avatar
if they don't line up, they could be the smaller dx brakes...which I would find surprising and stupid.
What is the distance between the holes?
Old Jan 21, 2005 | 08:17 AM
dantastic's Avatar
Default Re: Front rotor size 96-00... (CycloneBlue_1.6EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL &raquo;</TD></TR><TR><TD CLASS="quote">Okay, I know the 96-00 EX models have 10.3" front rotors. This is my dillema... My 1997 Acura 1.6EL should have the same 10.3" front rotors/calipers/knuckle as the 96-00 Civic EX because it's essentially the same car. I bought a steering knuckle from the pick and pull from a 1997 Civic EX, and the caliper mounting holes didn't line up. Are my EL's front rotors larger than the EX's 10.3? No ABS by the way...</TD></TR></TABLE>
in canada, i think you'll need EX-R front brakes.
USDM -&gt; CDM
LX -&gt; EX
EX Sedan -&gt; EX-R Sedan
EX Coupe -&gt; Si
Si -&gt; SiR
** edit: oops. not sure if the top-of-the-line EK sedan was the EX, EXR, OR Si....
Old Jan 21, 2005 | 09:40 AM
carolinahondaboy's Avatar
Default Re: Front rotor size 96-00... (dantastic)
while your at it get some power slots
Old Jan 21, 2005 | 01:57 PM
_Cyclone_'s Avatar
There aren't any EX-R civics... there are EX-R Accords, but not civics. Maybe there are different trim levels of the EX or something where they came with 9.5" and 10.3" brakes... I'm not sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carolinahondaboy &raquo;</TD></TR><TR><TD CLASS="quote">while your at it get some power slots </TD></TR></TABLE>
This thread isn't about changing the brakes, it's about the steering knuckle and rotor sizes between different models. Besides which, I wouldn't buy "power slots" anyways, I'm replacing the factory rotors with Brembo blanks in the spring. Brembo blanks &gt; power slots IMO.
blackstar
May 10, 2005 03:56 PM
ruthless013
Jul 12, 2002 09:34 PM
