obd2a-obd1 conv. questions
what do i need?...i have the conv. harnesss but im not sure what type of ecu to run p28??? anddo i need to change my distributor or get a new harness?...all the help i can get would be greatly appreciated..thanks
you just need a OBD1 ECU. i can't tell you what ecu you need. that depends on your setup. there are many ecus out there. p28, p75, p72, etc... you don't have to change your distributor or harness. the jumper does everything for u.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 »</TD></TR><TR><TD CLASS="quote"> the jumper does everything for u. </TD></TR></TABLE>
what jumper?? you mean the ecu conversion harness takes care of the distributor harness?
