diy removeable cam gear cover
Old Jan 20, 2005 | 11:58 PM
morepoop4u's Avatar
Default diy removeable cam gear cover
before
after
Modified by morepoop4u at 12:04 AM 1/22/2005
Old Jan 21, 2005 | 02:48 AM
SlowReaction's Avatar
Default Re: diy removeable cam gear cover (morepoop4u)
Creative
Old Jan 21, 2005 | 04:56 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Nice work. That's a damn good idea, for a couple of reasons. For one, it eliminates the chance of fingers, or tools getting into the cam gears, if someone isn't paying attention. Plus for the sneakey type, who don't want anyone to know what their settings are, it keeps them secret. Nice work man, keep it up
Clayton
Old Jan 21, 2005 | 05:08 AM
rhd's Avatar
rhd
make and sell??????
Old Jan 21, 2005 | 06:11 AM
WhatThaFrig's Avatar
Default Re: (xhardcoresucksx)
That is very creative. Good work!
Old Jan 21, 2005 | 08:23 AM
Nikoli's Avatar
Default Re: (WhatThaFrig)
how much?
Old Jan 21, 2005 | 08:38 AM
StyleTEG's Avatar
Default Re: (Deckedlude)
Very cool. Like the idea.
Old Jan 21, 2005 | 09:16 AM
2point2's Avatar
Default Re: (StyleTEG)
just like a ZC!
Old Jan 21, 2005 | 11:58 AM
Chronicsinners's Avatar
Default Re: diy removeable cam gear cover (Clayton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clayton &raquo;</TD></TR><TR><TD CLASS="quote">Nice work. That's a damn good idea, for a couple of reasons. For one, it eliminates the chance of fingers, or tools getting into the cam gears, if someone isn't paying attention. Plus for the sneakey type, who don't want anyone to know what their settings are, it keeps them secret. Nice work man, keep it up
Clayton</TD></TR></TABLE>
tru, also important is the premature wear on the tbelt, being exposed to the elements
Old Jan 21, 2005 | 02:22 PM
CRXDrew's Avatar
nice and clean. good job
Old Jan 21, 2005 | 03:03 PM
morepoop4u's Avatar
Default Re: (CRXDrew)
sorry i don't sell, it was just a weekend project. if you want to make your own all you need is 16 gauge sheet metal, a grinder, a saw, a welder, and paint. you'll need these 10mm screws.
just cut a 2 inch wide strip of sheet metal and bend it to follow the contours of the valve cover. you can make it as long as you want. then just weld a flat piece to the side of it and grind the edges to round them. i welded it on the inside so you wouldn't see my flux core welds thus eliminating the need for extra grinding on the outside.
Old Jan 21, 2005 | 04:52 PM
cxSHOE's Avatar
is it just a cover? or did you cut off that last section of the valve cover and then add this&gt;&gt;&gt;&gt; hence to make changing your belts easier without taking the valve cover off.
Old Jan 21, 2005 | 05:32 PM
SUB-0 H23's Avatar
Default Re: diy removeable cam gear cover (cxSHOE)
good ****
Old Jan 21, 2005 | 06:31 PM
LD_EGSICK's Avatar
Default Re: diy removeable cam gear cover (SUB-0 H23)
i really like the idea
Old Jan 21, 2005 | 07:23 PM
Mr HYDE's Avatar
Default Re: diy removeable cam gear cover (LivinDreamsDC2)
this right here is an awesome idea, back when i first built my all motor itr set up, i almost lost it due to a bolt dropping in the dust cover and getting stuck rubbing the belt almost cutting it in half lucky for osme reason i pulled the valve cover off and saw it before it happened, and this was literaly 3 hours after i got it running and the motor had like 10 miles on it,
here a some pic of my belt
Old Jan 23, 2005 | 12:40 PM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">is it just a cover? or did you cut off that last section of the valve cover and then add this&gt;&gt;&gt;&gt; hence to make changing your belts easier without taking the valve cover off.
i'm assuming he left at least some of the end of the valve cover since the mounting points on his cover correspond to the two threaded holes on the end of the valve cover.
chris
Old Jan 23, 2005 | 12:45 PM
MissMyHonda's Avatar
Smart idea
Old Jan 23, 2005 | 11:32 PM
CivicHatchback14's Avatar
Thats sic man...
Old Jan 24, 2005 | 08:43 AM
integ22's Avatar
Default Re: diy removeable cam gear cover (CivicHatchback14)
Good idea
Is that a modified stock strut bar i see?? Good idea as well
fwdtamiya
Dec 27, 2006 07:05 PM
SlowPokeEg
Jan 22, 2005 10:35 PM
morepoop4u
Jan 21, 2005 03:29 PM
mp5o
11
Jan 4, 2005 05:46 PM
Mike M
Aug 19, 2001 08:26 PM
