Skunk2 OBD2 to OBD1 adapter harness and Hondata stage 2b
Have the harness adapter and a P72 OBD1 GSR ecu, gonna use the hondata stage 2b. Will I have any problems with my immobilizer????? Will it work or won't it???
It will work just fine I think...not sure if you'd have to wire in a knock sensor or if the Hondata can "ignore" that on the P72 ECU
basically, I will have to get a aftermarket alarm with a ignition cut. I have the dealer installed acura alarm right now.....
I got the P72 (94-95 GSR) ECU which has the knock. I think the P28 doesn't have the knock sensor. SGT can you verify this?
Rawgie
Jul 8, 2005 07:24 AM
JDMCRX
Aug 31, 2004 03:29 AM
