Clutch push rod bolt
Old Jan 20, 2005 | 07:56 PM
megaman096's Avatar
Default Clutch push rod bolt
I am wanting to adjust the push rod on my clutch pedal because mine releases a little to high for my likings. So I was down there and i was trying to loosen the bolt 12mm i am pretty sure and it wouldnt budge! Which why do I turn it , I know right is tight left is loose but from which way would it be? Do I turn it towards the outside of the car or the inside towards the passenger? Any help on how to loosen this bolt????
Old Jan 20, 2005 | 08:56 PM
megaman096's Avatar
Default Re: Clutch push rod bolt (megaman096)
bump . someone help a noob
Old Jan 20, 2005 | 09:04 PM
dantastic's Avatar
pg 12-4 in the EG helms manual. sorry i don't have a scanner...
Old Jan 20, 2005 | 09:05 PM
megaman096's Avatar
Default Re: (dantastic)
yeah thats what I am going by
but I need to know which way to turn the sucker and why it wont budge?
Old Jan 20, 2005 | 09:08 PM
Kamin's Avatar
Default Re: (megaman096)
um looking at the bolt from behind it turn it left...its really not that hard man lol, if its not budging one direction try the other, its just a little bolt. no need to get crazy on it and break something.
Old Jan 20, 2005 | 09:10 PM
megaman096's Avatar
Default Re: (Kamin)
but it seems as if the wrench wants to slip off on me, becuase the rod moves with it.
Old Jan 20, 2005 | 09:21 PM
Kamin's Avatar
hold the rod with a pair of pliers.
94eg!'s Avatar
#1 Super Guy
Loved
Get a flare nut wrench.
Old Jan 21, 2005 | 03:58 AM
ironlung78's Avatar
you have to hold the rod with a pair of pliers while you loosen the nut.. back the nut off with the wrench and use the pliers to turn the rod.. the more visible threads that are shown toward the rear of the car it should grab lower... the more visible threads visible toward the firewall grabs higher. When your happy, hold the rod with the pliers so it doesn't spin while your tightening the nut to hold it where you adjusted it..
**Make sure you have enough free play** It could take a bunch of times to get it adjusted the way you want, so leave the pliers/wrench in the car in case you need to adjust it down the road
Balor_Gr
Engine Machining & Assembly
Jun 30, 2018 04:06 AM
ragnarok0mega
May 22, 2013 06:18 AM
JBirch_97Prelude
Jun 27, 2009 10:07 AM
lude98SH
Jul 31, 2008 06:18 AM
crxzcracer
13
Feb 15, 2005 04:44 PM
