car bogs/hesitate when turning left
Old Jan 20, 2005 | 07:52 PM
216.226.142.95:27016's Avatar
Default car bogs/hesitate when turning left
when i make a left turns, my car bogs or hesistates a bit. i checked the oil level and its on the middle of the dipstick. what else can it be?
Old Jan 20, 2005 | 08:37 PM
rough_draft's Avatar
is it only left turns? is it from a stop?
Old Jan 20, 2005 | 10:10 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: (That vodka That Sprite)
somehow when you are turning, you might possibly be pinching a fuel line. Possibly.
Old Jan 20, 2005 | 10:14 PM
GsR-Freak's Avatar
Default Re: car bogs/hesitate when turning left (216.226.142.95:27016)
it would help more if you tell us how fast u turn and at what rpm....did you released the gas pedal or push more gas...etc stuffs like that...
what you told us is like saying " you hit a dog and he starts parking and get hessitates" you didn't tell us where you hit and how hard you hitted...
Old Jan 20, 2005 | 10:17 PM
GsR-Freak's Avatar
well from a scatch this is what i csan tell you for now....when most people turn they have a tendency to release the gas pedal and caused the fuel line cut off. in your case is prolly the same but your engine may have runs a little rich so when release the gas pedal the bogging and hesitates causes by unburned fuels popped in the exhaust piping manifold?
bad guess or good guess?
Old Jan 21, 2005 | 04:25 PM
Default Re: car bogs/hesitate when turning left (GsR-Freak)
not a fast turn at all. this happens in everyday driving in the city. when i turn, i dont get off the gas then floor it, i brake, gas slightly, and keep it at that level until going straight.
today, when i turned left, it happend after maybe 10-20 feet going straight. my rpm wasnt high, i wasnt on the gas hard, just barely, and my car bogged. how can i pinch a fuel line while turning? where in the car would it be?
thanks
Old Jan 21, 2005 | 10:41 PM
up
Old Jan 24, 2005 | 12:53 PM
GsR-Freak's Avatar
can you describe how does the bogging sound like and how does it gets hestitates? the sound the feeling u got, give me some more info
Old Jan 24, 2005 | 02:27 PM
fastrunner's Avatar
sounds like the pickup in your fuel tank is clogged or pushed over to one side, does it do this when you have a full tank of gas or only when there is just a lil gas in your tank.
Old Jan 25, 2005 | 08:53 PM
Default Re: car bogs/hesitate when turning left (fastrunner)
hmm never really paid close attention to fuel level since ive been just letting the car coast while turning. but it has happend in half a tank of gas.
as far as decription goes, the rpm is lets say at 3,000 rpm while im on the gas. it would drop 500-700 rpm, car boggs, then goes back up. this is one thing ive noticed a lot since it has happend.
im thinking it could be some wiring with my vafc i might check that if that might cause. loose connections maybe?
Old Jan 25, 2005 | 09:56 PM
tegmech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrunner &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the pickup in your fuel tank is clogged or pushed over to one side, does it do this when you have a full tank of gas or only when there is just a lil gas in your tank.</TD></TR></TABLE>
possibly, i would check that first.
however integras are notorious for their left side muffler bearing going out. be careful you might lose the right side.
Old Jun 25, 2009 | 11:55 AM
sqeeek's Avatar
My 1996 Honda Accord EX has the same problem - and once, the engine light came on, and the DAC gave me a p0401 code, saying the EGR valve wasn't working... i've replaced and cleaned the whole EGR system, i finally found a plate under the injectors that was full of carbon... but it still hesitates. It's really starting to **** me off... but anyway, check your EGR valve, mine hesitated for about 3 weeks before the engine light came on.
fridayfred3p
Dec 31, 2005 08:40 AM
extreme90civic
Aug 29, 2005 06:45 PM
omg_miiiike
Apr 27, 2005 09:27 AM
from_zer0
May 27, 2004 11:06 AM
2k1_ITR_0736
Feb 15, 2003 01:37 PM
