Gas spilling from my fuel rail..
Old Jan 20, 2005 | 07:18 PM
jaydm ferio's Avatar
Default Gas spilling from my fuel rail..
alright guys i just put my sohc motor back in my car and it has been smelling like gas(bad). today I poped my hood and there was gas spilling from my fuel rail
(only while my car is on). What should i look for, or what do I tighten on it? thanks
btw they are stock injectors on a 99 civic.
Old Jan 20, 2005 | 07:20 PM
tominos's Avatar
Default Re: Gas spilling from my fuel rail.. (jaydm ferio)
exactly which point on the fuel rail is it leaking from? could be leaking from the fuel inlet line, or where it goes back into the tank, or from the injectors(o-rings). maybe you're missing a washer or it's loose..
HATCHingMN's Avatar
get it fix and dont drive it, or you're fired!!
Old Jan 20, 2005 | 07:21 PM
Kamin's Avatar
Default Re: Gas spilling from my fuel rail.. (HATCHingMN)
seriously where is it leaking from? that would help.
Old Jan 20, 2005 | 07:30 PM
Default Re: Gas spilling from my fuel rail.. (Kamin)
its not from where the big nut is on tha fuel rail, Its right above the injectors though, the whole fuel rail seems like its leaking.
Old Jan 20, 2005 | 07:34 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio &raquo;</TD></TR><TR><TD CLASS="quote">its not from where the big nut is on tha fuel rail, Its right above the injectors though, the whole fuel rail seems like its leaking.</TD></TR></TABLE>
it sounds like your injectors are not properly seated in the fuel rail OR the o-rings are bad. it's really easy to pinch the o-rings when installling injectors (i've done it like 3 times). install the injectors into the rail first then install the rail w/injecotrs as a unit
Old Jan 20, 2005 | 07:40 PM
Default Re: Gas spilling from my fuel rail.. (dantastic)
so should i just pull em out and put em back in tighter or wut?
Old Jan 20, 2005 | 07:41 PM
JDMTurboCivic11's Avatar
get new o-rings for a few bucks
Old Jan 20, 2005 | 07:49 PM
Default Re: Gas spilling from my fuel rail.. (JDMTurboCivic11)
can i go to autozone for em? btw how do I tighten my injectors?
Old Jan 20, 2005 | 07:56 PM
EK k kay's Avatar
I had that problem. It was the rubber o-rings. Just take the injectors off and twist them back into the fuel rail while making sure that the o-rings go all the way inside and the injector is flush with the fuel rail.
Old Jan 20, 2005 | 07:59 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio &raquo;</TD></TR><TR><TD CLASS="quote">can i go to autozone for em? btw how do I tighten my injectors?</TD></TR></TABLE>
just de-pressurize your fuel system and remove the fuel rail. take out each injector and inspect each o-ring. if they're not in perfect shape, buy new ones. i had to get mine from the dealer ($2 each?). now just put on the new o-rings and use a tiny bit of oil to soften the o-ring. then install each injector into the fuel rail, making sure they sit flush. then re-install the fuel rail and injectors as an assembly.
Old Jan 20, 2005 | 08:01 PM
how do i de-pressurize my fuel system ?
Modified by jaydm ferio at 5:19 AM 1/21/2005
Old Jan 20, 2005 | 11:47 PM
tominos's Avatar
pull the fuse to the fuel pump. loosen one of the bolts to the fuel pump, but place a rag over the wrench to catch the spraying fuel.
410ruga
Apr 10, 2014 03:46 AM
ludedude95
Feb 15, 2004 06:50 PM
pureplayaz704
Mar 29, 2003 11:55 PM
JoshRambo
Sep 16, 2002 03:54 AM
