How will the alternator/charging system hold up to this?
Old Jan 20, 2005 | 05:29 PM
Intercooler's Avatar
Default How will the alternator/charging system hold up to this?
See car in sig.
I plan on upgrading here soon and am in the process of working out the details. Will my charging system be taxed with a Kicker 800.4 and Kicker 600.1 both running? How much less shock to the system would just running the Kicker 800.4? This may sway me from putting a sub in the car or not.
Old Jan 21, 2005 | 08:03 AM
fcm's Avatar
fcm
Old Fart
Default Re: How will the alternator/charging system hold up to this? (Intercooler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Intercooler &raquo;</TD></TR><TR><TD CLASS="quote">See car in sig.
I plan on upgrading here soon and am in the process of working out the details. Will my charging system be taxed with a Kicker 800.4 and Kicker 600.1 both running? How much less shock to the system would just running the Kicker 800.4? This may sway me from putting a sub in the car or not. </TD></TR></TABLE> Anything that you add to the car that draws power will have an affect on the charging system, how big of an affect will depend on how big the draw is, http://www.the12volt.com go there and you can find out how much power your amps will use, that said, evan running just one of the amps will put a heavy load on the charging system, although you can put both in, and as long as you don't crank it up to loud you can get away with it, but if you like it loud, the first thing to do is upgrade the alt. and maybe the batt. and add a 1 farad cap to the sub amp 94
fhukyea
Sep 4, 2009 12:12 PM
Master_maverick
Audio / Security / Video
Aug 14, 2009 06:39 AM
iixerOii
May 12, 2007 10:31 AM
91teg4dr
Feb 7, 2004 03:29 AM
