Scion Spy Pics 2
Old Jan 20, 2005 | 04:36 PM
Fisch's Avatar
Default Scion Spy Pics 2
"We're into the second week of the Scion tC Hot Rod project. After the clean up was finished. The cage has been installed (25.5). Note bottom tubes are under floor pan. The frame will be welded to the original sheet metal at all possible locations. The tubing to the rear shock towers are mandated b the 25.5 spec. The front shock towers are being seam welded for strength. The rack has been converted to non power-steering. The top pic is of the new GM Hub assembly with the Mark Williams hubs and carbon brakes (same as the Honda hub). This gives Mark Williams pretty good coverage of the fwd drag race market.
Next we'll show the rear carbon straignt axle, the diffusor, and the mandated steel roof that replaces the glass roof. We decided to put it in after the roll cage is welded." Bob Norwood
Old Jan 20, 2005 | 04:42 PM
bergenholtzracing's Avatar
Default Re: Scion Spy Pics 2 (Fisch)
Fisch is alive! Good work to the Norwood camp!
Old Jan 20, 2005 | 04:44 PM
alternativechuck's Avatar
looks good fisch, you guys keep up the good work
ninesecrx's Avatar
Dont you think the front slicks are gonna rub going down the track?
Old Jan 20, 2005 | 04:46 PM
Hey fisch is that the new strange front struts??
Old Jan 20, 2005 | 04:48 PM
adrenalinjunkie's Avatar
Default Re: Scion Spy Pics 2 (alternativechuck)
cool!
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alternativechuck &raquo;</TD></TR><TR><TD CLASS="quote">Hey fisch is that the new strange front struts??</TD></TR></TABLE>
Yup, same setup you're getting
Old Jan 20, 2005 | 04:50 PM
HR-1320's Avatar
Default Re: Scion Spy Pics 2 (bergenholtzracing)
Looks nice guys. Whats this about the tubes needing to be tied into the rear strut towers. I read by sfi book cover to cover but it didn't specify for a fwd. It just showed common procedure fo a rear wheel drive. There really only concerned about the driver compartment anyway, at least to my knowledge that is. Any elaberation would be appreciated thanks.
Default Re: Scion Spy Pics 2 (tony1)
looks like a clean setup
Old Jan 20, 2005 | 04:57 PM
DIFFUT'S INC.'s Avatar
mMmMMmMMMmmM
Old Jan 20, 2005 | 05:06 PM
TyCooley's Avatar
Default Re: Scion Spy Pics 2 (DIFFUT'S INC.)
Cool! nice work fisch and norwood crew!
Old Jan 20, 2005 | 05:34 PM
bambooluv's Avatar
Default Re: Scion Spy Pics 2 (TyCooley)
nice
Old Jan 20, 2005 | 06:23 PM
tony1's Avatar
Default Re: Scion Spy Pics 2 (2.0Coupe)
The book doesn't specify anything being fwd or rwd. There's one spec for everything. You're right, it doesn't make sense for a fwd car, but we're not about to build it different only to find it's not legal!
Old Jan 20, 2005 | 06:39 PM
HR-1320's Avatar
What I'm saying is that I didn't know anything outside the the drivers compartment was mandatory. A rear wheel drive can be narrow and to the suspension points where a our cars are wide and to the strut towers. They don't show it like that in there specs.
Old Jan 20, 2005 | 06:42 PM
tony1's Avatar
They show 3 or 4 different options for the rear bars. We can only assume that you have to pick one. Even though they're not exactly like in the pics, if the pic calls for 1.25" .058 in an X, then that's what you do...
Old Jan 20, 2005 | 06:46 PM
Adam F's Avatar
Looks good guys
Old Jan 20, 2005 | 06:52 PM
BoogieDownBrown's Avatar
can we get some more info on the hub assembly(price..etc.) and what tranny you guys using. thanks
Old Jan 20, 2005 | 06:54 PM
tony1's Avatar
Default Re: Scion Spy Pics 2 (BoogieDownBrown)
All the drivetrain parts (brakes, hubs, and axles) are from Mark Williams. Have to contact them for price. The spindles are oem GM pieces. Still deciding on trans, leaning towards Xtrac...
Old Jan 20, 2005 | 06:57 PM
from what gm vehicle??
looks good by the way. and thanx for the info.
Old Jan 20, 2005 | 06:59 PM
tony1's Avatar
98 grand prix...
Old Jan 20, 2005 | 07:01 PM
thank you very much again.
Old Jan 20, 2005 | 07:04 PM
tony1's Avatar
No problem, we're glad to help. We'll do whatever we can to get more cars on the track!
Paradise Racing's Avatar
Hey boogie, leave the TC alone!!! Your wife would kill you if you showed up with your TC chopped up like that Hell my wife would kill me too
Tony, kick *** job!!!
Old Jan 20, 2005 | 07:08 PM
fknfast's Avatar
Default Re: Scion Spy Pics 2 (Paradise Racing)
somethings BREW'N
Old Jan 20, 2005 | 07:45 PM
crx12's Avatar
Default Re: Scion Spy Pics 2 (fknfast)
Lookin good guys!
