skunk2 intack manafoled idling problems?
Old Jan 20, 2005 | 03:49 PM
THEO-Vtec's Avatar
Default skunk2 intack manafoled idling problems?
I put a skunk2 intake manifold on my b16 and ever sins it idles like 1500 RPM's and sometime it lops between 1200 and 2000. i can't figure it out. anyone have any ideas?
Old Jan 20, 2005 | 05:35 PM
HEAD's Avatar
Default Re: skunk2 intack manafoled idling problems? (THEO-Vtec)
Vacuum leak, manifold is leaking around the gasket. It's been so long but I think if you shoot brake clean around the manifold to see where the leak is. RPM will shoot up. Not sure again of how to diagnose it's been incredibly long time since I worked on a car.
Old Jan 20, 2005 | 05:36 PM
StorminMatt's Avatar
This sort of problem can be most frustrating to fix. The first thing to look for is any kind of air leak, as this can cause problems. Air leaks can, of course, occur at the gaskets as well as any of the vacuum taps. If this does not solve the problem, you might have a bad IACV. Also check your coolant. Sometimes, air pockets in the cooling system can cause the idle valve on the throttle body to malfunction, causing a similar problem. Make sure it is properly bled.
Old Jan 21, 2005 | 06:26 PM
THEO-Vtec's Avatar
Default Re: skunk2 intack manafoled idling problems? (StorminMatt)
thanks, i could be the coolant i did have a hard time gitting it to fill. how do i properly bled? i just added more as i slowly want down.
Old Jan 21, 2005 | 06:57 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEO-Vtec &raquo;</TD></TR><TR><TD CLASS="quote">how do i properly bled?</TD></TR></TABLE>
Remove radiator cap when motor is cold, start car, turn on heater and set the blower to the highest speed. Let the car reach normal operating temp. Air will rise and come out of the radiator fill neck.
ncVTEC1313
Apr 22, 2013 12:24 AM
egCoupe
Aug 31, 2005 08:18 PM
duberz
Oct 14, 2004 03:03 PM
germanEE8
Feb 25, 2004 08:56 AM
ncVTEC1313
Dec 22, 2003 01:49 AM
