Suspension & Brakes Theory, alignment, spring rates....
92 Civic Rear Wheel Bearings!
Old Jan 20, 2005 | 03:26 PM
timntam's Avatar
Default 92 Civic Rear Wheel Bearings!
I've got a 92 LX and need to change the rear wheel bearing. Is it easy to remove? Will I be able to do it in my drive way with out air tools?
I have rear drum brakes, not disc!
Old Jan 20, 2005 | 05:03 PM
b18ccivics's Avatar
Default Re: 92 Civic Rear Wheel Bearings! (timntam)
you can only buy the whole hub assembly to my knowelege. to change it you have to take off the brake drumb then use a screw driver to pry the dust coveroff the hub then take the nut off the spindle and you are done.
Old Jan 20, 2005 | 07:34 PM
TrakDay's Avatar
Default Re: 92 Civic Rear Wheel Bearings! (b18ccivics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics &raquo;</TD></TR><TR><TD CLASS="quote">you can only buy the whole hub assembly to my knowelege. to change it you have to take off the brake drumb then use a screw driver to pry the dust coveroff the hub then take the nut off the spindle and you are done.</TD></TR></TABLE>
that's correct
JaguarS4R
Honda Civic (2001 - 2005)
Oct 21, 2010 04:32 AM
BDogggUT34
Sep 21, 2007 03:04 AM
bward
Jul 17, 2006 07:40 AM
743power
Dec 21, 2003 05:43 PM
92BlackSi
Oct 12, 2003 06:07 AM
