turbo exhaust manifold
Old Jan 20, 2005 | 02:46 PM
andysila's Avatar
Default turbo exhaust manifold
for a 3" downpipe comming from the exhaust.. does my exhaust manifold have to also be 3" or what.. can someone explain how that works
Old Jan 20, 2005 | 03:29 PM
a1320addict's Avatar
Default Re: turbo exhaust manifold (andysila)
the downpipe doestn come from the exhaust...it comes off the turbine housing on the turbo and in some cases bolts right up to the cat...some instances deletes the cat....the size of the downpipe varies...and the diameter of each exhuast manifold runner doesnt really have anything to do with the down pipe...its the bolt pattern and size of the turbine housing that varies the size of the downpipe...but you can always flare it
Old Jan 20, 2005 | 05:57 PM
JdmEKCivic's Avatar
Default Re: turbo exhaust manifold (yehiknowrite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yehiknowrite &raquo;</TD></TR><TR><TD CLASS="quote">the downpipe doestn come from the exhaust...it comes off the turbine housing on the turbo and in some cases bolts right up to the cat...some instances deletes the cat....the size of the downpipe varies...and the diameter of each exhuast manifold runner doesnt really have anything to do with the down pipe...its the bolt pattern and size of the turbine housing that varies the size of the downpipe...but you can always flare it</TD></TR></TABLE>
Turbo_Mike
Nov 18, 2006 07:09 PM
KeithGSR
May 4, 2004 11:17 PM
rice a roni
Dec 28, 2003 01:40 PM
Apex i ITR
Feb 7, 2003 07:46 AM
Tofurky
Dec 3, 2002 11:21 AM
