can bad axles cause wandering
My alignments ok and tires are fine, but my car wanders really easy and dont feel tight to the road. Could worn out axles cause it to wander really bad and make the car not feel solid? Also could upper balljoints cause this even if theres not play or slop in them but still might be bad? steering rack and tie rods are all tight.
koni adj's
eibach prokit
energy suspension masterkit
upper tiebar
koni adj's
eibach prokit
upper tiebar
i mean the car tracks all over the road, u gotta white knuckle the wheel most of the time. Any little crack or bump in the road throws the car really easy and its pretty scary.
i have the same problem.
Real scarry. i've changed to coil-overs, Energy bushings, upper shock tower bars in front and back, and lower tie on rear.
My **** still wanders all over god's creation.
Mine does the same thing ever since the swap was done. i got pretty used to it but my friends always complain if they drive my car how loose it feels.
EDIT: i changed my axles since the 1st set was bad and it still does it.
Rack and pinion, tierods, wornout or rotting bushings. Check how my play you have (looseness) when you have to turn. Is there any amount of free play before the wheels actually repond? Do your tierod ends look chewed up and have a lot of free play (not tight)? Best of luck
Note: Jack the car up, secure it with stands on the rails. Then make sure the streering lock is undone (key in). With your own power at one of your front wheels, try to make them turn. See how much free play there really is. That can help in figuring out what is or is not wrong with yourt steering/suspesion system.
I would say its your bushings. The axles are only there to supply power to the wheels, a worn bushing will cause your sttering to feel loose or wander on the road, especially at highway speeds.
if tire wear is normal, check your caster. sounds like you need a little more positive caster. that could come from chassis damage. Toe out may also cause that, but caster does not cause wear, while toe does. Also check your rack alignment. a crooked rack could cause bump steer.
CRXB16T
11
Nov 10, 2005 07:29 AM
