obd-0 po3 ecu into ef obd-0 z6 motor????
Old Jan 20, 2005 | 01:26 PM
AZTEKEF9's Avatar
Default obd-0 po3 ecu into ef obd-0 z6 motor????
i have a ef and just did a full z6 swap... but i kept it obd-o. whanted to know if i can use a obd-0 po3 so i can activate the v-tec... i have runned a pm6 and pm7 but hve not hooked up the v-tec...... my friends has a ef with the b16 and the po3 obd-0 ecu.....he's changing to a p28 obd-1 so he said i can have the po3.....
can i run it in my car with no mod......? any help.....
Old Jan 20, 2005 | 04:15 PM
AZTEKEF9's Avatar
Default Re: obd-0 po3 ecu into ef obd-0 z6 motor???? (AZTEKEF9)
any1?
Old Jan 21, 2005 | 04:23 PM
AZTEKEF9's Avatar
bump....
Old Jan 22, 2005 | 08:26 PM
doublethink's Avatar
no.
very wrong fuel maps, incorrect power band, redlines too high.
Old Jan 22, 2005 | 08:30 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZTEKEF9 &raquo;</TD></TR><TR><TD CLASS="quote"> i can activate the v-tec... i have runned a pm6 and pm7 but hve not hooked up the v-tec</TD></TR></TABLE>
you will need to use the pm6 or pg7, no clue what a pm7 is. And need to hook up vtec some other way.
Old Jan 22, 2005 | 08:48 PM
-16V-'s Avatar
Default Re: obd-0 po3 ecu into ef obd-0 z6 motor???? (Mach69)
Pm7 88-89 integ
Old Jan 22, 2005 | 09:08 PM
CUSTOMCONNECTION's Avatar
po3..... or pr-3...... if its pr3 u can use it ...just add knock sensor and vtec wires and go.......
Old Jan 23, 2005 | 02:08 PM
AZTEKEF9's Avatar
Default Re: obd-0 po3 ecu into ef obd-0 z6 motor???? (CUSTOMCONNECTION)
sorry its is a pr3....it has the mugen chip....so i only need one o2 sensor... i don't know about the nock sensor...
Old Jan 23, 2005 | 03:03 PM
Boosted Chemist's Avatar
pm6 chipped with vtec control or ps9 chipped, or an obd1 conversion
pm me for a chipped ecu, i can copy z6 maps to a pm6 ecu
Old Jan 23, 2005 | 03:05 PM
87sivtec's Avatar
mugen chip doesn't use any O2 sensors.
Old Jan 23, 2005 | 06:47 PM
FuRiO27's Avatar
bump.............
Old Jan 23, 2005 | 07:16 PM
AZTEKEF9's Avatar
Default Re: obd-0 po3 ecu into ef obd-0 z6 motor???? (87sivtec)
wow......
but would this ecu work on my set up?
Old Jan 23, 2005 | 11:48 PM
mcleod's Avatar
i do run a PW0 SIR 88-91 ECU for my d16y8, but maybe you should think about a v-afc or something like that, maybe run turboedit to lean mixture!
but it work well even if it RICH as hell at 6000+
you should use a knock sensor...
Old Jan 24, 2005 | 05:17 PM
AZTEKEF9's Avatar
Default Re: obd-0 po3 ecu into ef obd-0 z6 motor???? (mcleod)
where can i install the knock sensor? and how can i get it....?
efkid88
Jul 10, 2010 03:48 PM
88 EF Hatch
Aug 8, 2009 12:24 PM
sway892
Aug 21, 2008 08:42 PM
FOMULA91
Jul 23, 2005 10:02 PM
