My melted P28 ECM
Old Jan 20, 2005 | 01:02 PM
brookliner7's Avatar
Default My melted P28 ECM
any ideas what caused this!?!?!?
It was running my LsVTEC...
Old Jan 20, 2005 | 01:09 PM
eL's Avatar
eL
too much vt4Ch y0
Old Jan 20, 2005 | 01:14 PM
Jim Truett's Avatar
Default Re: My melted P28 ECM (brookliner7)
If the failure is localized to that capacitor, I would assume an internal failure within the capacitor. If the circuit board is not burned too badly, it will be a fairly straightforward repair.
Old Jan 20, 2005 | 07:18 PM
board looks burned on back too....hmmm
Old Jan 20, 2005 | 07:25 PM
project.mu's Avatar
Default Re: (brookliner7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brookliner7 &raquo;</TD></TR><TR><TD CLASS="quote">board looks burned on back too....hmmm
wanna sell it i need some parts off it...
Old Jan 20, 2005 | 07:38 PM
kazino42's Avatar
Default Re: (n1taboo)
Looks like you put the chip on the wrong way. The notch is suppose to go the other way.
Old Jan 20, 2005 | 07:50 PM
Jim Truett's Avatar
Default Re: (kazino42)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kazino42 &raquo;</TD></TR><TR><TD CLASS="quote">Looks like you put the chip on the wrong way. The notch is suppose to go the other way.</TD></TR></TABLE>
Good eye
If you have applied power to it, consider that chip smoked. The Mugen program is generally junk anyway.
I usually charge around $40 to reconstruct the PCB when there is a burn-through.
Old Jan 20, 2005 | 08:13 PM
Benbuilt4u's Avatar
bet that smells great
Old Jan 20, 2005 | 08:39 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: My melted P28 ECM (Benbuilt4u)
lol
thats a DSM issue with bad caps.
I think you just have a bad caps, of course it might be worse because the caps leaked around the circuitboard
replace the caps, it's 3 bucks most and then see what happens!
Old Jan 20, 2005 | 09:27 PM
Smokinsax's Avatar
The Boot
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">too much vt4Ch y0 </TD></TR></TABLE>
to some, thats a serious problem for their ecm's
Old Jan 21, 2005 | 09:29 AM
eh?
I've had this chipped for almost two years now...
My LsVTEC was hitting 14 sec 1/4 miles in my full interior coupe with a/c, ps, and on street tires with this chip "upside down"
Like to see how it would run with it "right side up"
I've been pretty happy with the mugen chip considering I don't have AFC or VAFC and the car lays down consistant numbers.
anyways, a honda tech here said the only wires going to this capacitor were the ground and main power supply....
So, wouldn't the fusable links blow near the alt first before my ecm fries?
guess not is the answer! lol!
As far as selling it...probably.
I' getting a new chipped ECM then I'm gonna try and fix this one and see if it works, then I'll prolly sell it.
Old Aug 12, 2007 | 06:34 PM
PhuCDatBiCh's Avatar
DUDE!! same thing happen to my ecu!! so what do i need to do to fix this problem?? im running lsvtec too with p72 chipped and i try diff ecu p75 chipped and same spot melted dont know what to do! help please
Old Aug 12, 2007 | 07:53 PM
sageuvagony's Avatar
eh?
I' getting a new chipped ECM then I'm gonna try and fix this one and see if it works, then I'll prolly sell it.</TD></TR></TABLE>
That's weird becasue it's facing oposite of all other chips. Plus, look at the white outline around any of the chips. They are all rectangular with that C at the end.. kinda like this..
|..................C
The chip should match the white. I put dots in the pic since I couldn't use spaces (GRR HT)
And notice how that's the only chip facing that direction.. Even the letters on your chip are upside down. Was it already chipped when you bought this?
Old Aug 13, 2007 | 05:01 AM
Default Re: (sageuvagony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony &raquo;</TD></TR><TR><TD CLASS="quote">
|..................C
i dont think it cause of that..chip facing other direction mine was facing the right direction but same thing happen to mine ill pose pix later today
Old Aug 13, 2007 | 05:53 AM
Luserkid's Avatar
Default Re: (PhuCDatBiCh)
Only time i see capacitors blow like that is when IAC and EVAP plugs are switched. Did you touch your wiring harness recently by any chance?
Old Sep 26, 2007 | 11:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhuCDatBiCh &raquo;</TD></TR><TR><TD CLASS="quote">DUDE!! same thing happen to my ecu!! so what do i need to do to fix this problem?? im running lsvtec too with p72 chipped and i try diff ecu p75 chipped and same spot melted dont know what to do! help please</TD></TR></TABLE>
wow, all i did was replace mine and I didn't have any more probs.
Old Sep 26, 2007 | 11:59 AM
pgpunkguy's Avatar
UNLESS the chip was programmed backwards... then, backwards=correct.
Old Sep 26, 2007 | 01:11 PM
labtec2's Avatar
this might be VERY BASIC soo basic its too dumb to think about it.
but the little 1/2 moon or cresent shape thats on the MUGEN85R e-prom chip, its facing the wrong way.
I.E. Its in backwards
i had the same problem (smoking ECU) my problem however i had the intake temeperature sensor and the throttle position sensor miswired and consaquently (R135) on the board "fried" the car still runs...runs greats but that part of the ECU is toast.
i think your might be gone
Old Sep 26, 2007 | 01:37 PM
King V's Avatar
Default Re: My melted P28 ECM (labtec2)
Capacitor plague.
Old Sep 26, 2007 | 03:16 PM
Relic1's Avatar
electrolytics are getting old in honda ECUs they are dieing more and more commonly now.
Luserkid - Q30 pops when the EVAP and IAC are switched.
OP: If you're running with the chip that way then your CEL should be on and the car will run poorly compaired to having it in there correctly. It would also draw more power from the 5V line which would put slightly more strain on that cap... see where I'm going with this?
But the specific fuel and ignition maps of the limp mode in that ECU may happen to line up to your setup... it would be super lucky, but maybe.
B_CRUZ!
Northern California (Sales)
10
Feb 6, 2007 06:57 PM
Slimer
Jul 19, 2006 02:45 PM
7k rdlne
Oct 24, 2005 07:44 PM
backlash
Honda Motorcycles
19
Oct 12, 2005 05:02 PM
bardo
Jan 7, 2005 11:04 AM
