For Those With Full-Race Traction Bars...........
Old Jan 20, 2005 | 11:30 AM
b00stedbyFastrax's Avatar
Default For Those With Full-Race Traction Bars...........
how much adjustability are you getting. I have a set on and did an alignment and the bars would only give me 1.3 degrees of positive caster. I am wondering if I got too long of adjusting rods. btw, this is on a 1996 civic coupe.
thanks.
Old Jan 20, 2005 | 12:11 PM
philipwight's Avatar
Default Re: For Those With Full-Race Traction Bars........... (b00stedbyFastrax)
if the caster is 1.3 degrees possitive then you have the rods too short, you tightened them too much. set teh car on teh ground and set the length to were the bars dont pull the lca forward and dont push them back any either. then if you have caster problems look into bent components
edit- reread the post- mis understood it. take the bars off and see what the alignment is at. if the same then start looking for bent components
Modified by philipwight at 6:04 AM 1/21/2005
Old Jan 20, 2005 | 06:11 PM
Aggressive Racing's Avatar
if they are the competition engineering ones,i had to alter some for my costomer to fit his 2000 si,you might have to do the same.
Old Jan 21, 2005 | 01:03 PM
Default Re: For Those With Full-Race Traction Bars........... (aggressivemotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aggressivemotorsports &raquo;</TD></TR><TR><TD CLASS="quote">if they are the competition engineering ones,i had to alter some for my costomer to fit his 2000 si,you might have to do the same.</TD></TR></TABLE>
i am using the Full-race.
Old Jan 21, 2005 | 01:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00stedbyFastrax &raquo;</TD></TR><TR><TD CLASS="quote">
i am using the Full-race.</TD></TR></TABLE>
sorry didnt realize
Old Jan 21, 2005 | 03:43 PM
smokey2.0's Avatar
i have seen up to +7 degrees of caster, there's something wrong with your install or the bars. i suggest you post pictures of the bars on your car, so that other people can chime in!
Old Jan 21, 2005 | 06:41 PM
Default Re: For Those With Full-Race Traction Bars........... (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">i have seen up to +7 degrees of caster, there's something wrong with your install or the bars. i suggest you post pictures of the bars on your car, so that other people can chime in!</TD></TR></TABLE>
i will. who can host it?
Old Jan 22, 2005 | 08:22 AM
GRTechnologies's Avatar
i had to remove 1 of the jam nuts on both sides to get any adjustment
Old Jan 22, 2005 | 06:00 PM
93LSivic's Avatar
Default Re: (GRTechnologies)
Yes, seems like the FR bars are too long on my eg also. Spoke to Geoff about this, he said that I could cut the bars down a little. Be carefull not to mess the threads up, its best to have a thread chaser on hand after you do this.
jdmcx
Suspension & Brakes
Jun 17, 2014 06:56 AM
Wraith
10
May 2, 2005 06:54 AM
Marlon88
Apr 21, 2005 06:46 PM
System-7
Feb 19, 2005 12:21 AM
BoostedH23a1
May 22, 2003 08:59 AM
