Engine Question
Old Jan 20, 2005 | 10:25 AM
Hey Whats Up's Avatar
Default Engine Question
hey i'm adjusting the valves on a f22b1... i start off by rotating the camshaft pulley until it says 'UP" at the very top.
i adjusted first the exhaust valves and then the intake valves according to spec.
then according to instructions i rotate the camshaft pulley 90 degrees counter-clockwise until the UP mark is on the left side, pointing towards the car's windshield...
according to instructions here i'm supposed to proceed adjusting the 3rd piston's valves... but (unlike the first piston's valves) i checked the valve clearances FIRST before adjusting them, and i can barely even fit a .003 feeler in there...
if the valves are that far off spec, wouldnt they have burnt up or something by now? or am i just doing something wrong? or am i totally right and need to go ahead and adjust them back to spec?
thanks guys.
Old Jan 20, 2005 | 04:20 PM
civic-4-ges's Avatar
Default Re: Engine Question (Hey Whats Up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hey Whats Up &raquo;</TD></TR><TR><TD CLASS="quote">i adjusted first the exhaust valves and then the intake valves according to spec. </TD></TR></TABLE>
Did you do all the valves before you rotated your cam gear 90 degrees?
Old Jan 20, 2005 | 08:01 PM
Default Re: Engine Question (civic-4-ges)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">Did you do all the valves before you rotated your cam gear 90 degrees?</TD></TR></TABLE>
all the 4 valves on the 1st cylinder (exhaust and intake)
Old Jan 20, 2005 | 08:41 PM
SpdFrk's Avatar
thanks guys.</TD></TR></TABLE>
Your suppose to turn the crank 180 degrees counter clock wise(the camshaft will turn 90 degrees) and the UP marks will be facing the front(9 o'clock) of the motor not the windshield. Then adjust the number 3 clyinder.
"UP" mark:
cly.1 - 12 o'clock
cly.3 - 9 o'clock
cly.4 - 6 o'clock
cly.2 - 3 o'clock
ichikers
13
Jan 15, 2007 04:43 PM
lude98SH
21
Dec 13, 2006 01:36 PM
RyanG
Dec 12, 2006 12:10 PM
breathinez
Aug 24, 2004 10:35 AM
jdmkrazie
Jan 12, 2004 07:15 AM
