c pillar bar install
Old Jan 20, 2005 | 10:22 AM
boyer's Avatar
Default c pillar bar install
I searched and read every thread on this, but im having alot of trouble. I have an 88 si, and i unbolted the seat belts, attached teh bar on one side, and bolted it down i had to remove the big washer, like an inch long, b/c i couldnt get the bolt to go in otherwise, then i went to driver side did the same, but i need about 2" more
so the bar is to short, is there another place to mount it? or should i get longer bolts, and put the washer back on?
Old Jan 20, 2005 | 10:41 AM
EF_LSVtec's Avatar
Default Re: c pillar bar install (boyer)
if that bar is too short, I'm only assuming that it's the wrong bar...you sure that's made for your model car?
Old Jan 20, 2005 | 11:20 AM
Civic138's Avatar
Default Re: c pillar bar install (EF_LSVtec)
have you tried ajusting out the the pivots? (assuming you have an ebay one)
Old Jan 20, 2005 | 11:25 AM
Civic138's Avatar
like this one
Old Jan 20, 2005 | 11:30 AM
90 Si Hatch's Avatar
Default Re: c pillar bar install (Civic138)
Question, Do these Bars really help????
Old Jan 20, 2005 | 11:39 AM
boyer's Avatar
http://cgi.ebay.com/ebaymotors...%3AIT
This is the one i picked up.
edit: and yes i adjusted them out all the way.
Old Jan 20, 2005 | 12:23 PM
kenjief8's Avatar
Default Re: (boyer)
where do these mount to
Old Jan 20, 2005 | 12:34 PM
1boostedhybrid's Avatar
Default Re: (boyer)
I had the same thing happen to me. They sent me one that was too short. I just sent it back and have to wait for a replacement.
Old Jan 20, 2005 | 01:46 PM
Default Re: (1boostedhybrid)
DO THESE BARS REALLY WORK???
Old Jan 20, 2005 | 01:59 PM
crxtacy91sivtec's Avatar
Default Re: (White90SiHatch)
yes the bar really does work, the link you provided off ebay is a bar that goes in between the rear hatch not the seat belts..try that
Old Jan 20, 2005 | 02:45 PM
Civic138's Avatar
yea they really work
bracing any point on the chassis helps out alot
Old Jan 20, 2005 | 08:11 PM
boyer's Avatar
rear hatch, so i have to custom fab it?
Old Feb 1, 2005 | 08:31 AM
kenjief8's Avatar
Default Re: (boyer)
I have a 90 crx and there is no where to mount this.
i just got mine but have no where to mount it help please
Old Feb 6, 2005 | 06:56 PM
boyer's Avatar
Default Re: (kenjief8)
i got it to fit, i had to drill the hole on the bar bigger, and it mounted right up
Old Feb 6, 2005 | 08:45 PM
boosted440's Avatar
can somone post a pic if it installed in a crx..please ..
Old Feb 6, 2005 | 08:47 PM
erikiksaz1's Avatar
Default Re: c pillar bar install (boosted440)
Anything to tighten up our decade+ cars has to work
Mr.Death
34
Jun 30, 2013 03:51 PM
killercrx91
29
Dec 27, 2009 06:24 PM
court
Jan 29, 2009 05:52 PM
2004es2
Mar 3, 2008 07:13 PM
heyitzspikey
Nov 9, 2005 05:22 PM
