oxidization owned my car...
Old Jan 20, 2005 | 10:15 AM
cedete's Avatar
Default oxidization owned my car...
looks like a rainy cloud on the top of my beater...
i bought 1500 1000 and 320 grit sand paper along with some black primer...
dont have a clue about what im doing though..... Are these grits even right?
I searched and found some people say a 3m scuff pad or somethin..... i just want to sand it good and give it a little primer.. any suggestions? thanks
Old Jan 20, 2005 | 04:23 PM
nudvl's Avatar
PUT THE SAND PAPER DOWN AND STEP AWAY FROM THE CAR!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 20, 2005 | 04:58 PM
Shoobie's Avatar
Default Re: (nudvl)
Keep the paper off the car until you know what you're doing. You'll make the problem even worse. If you don't care (I guess since it's your beater, you could experiment a little) go with the highest grit you can find (like 2000, 2500).
Old Jan 20, 2005 | 05:26 PM
calxtreme's Avatar
If you're gonna do it, do some before and after pics too then.
Old Jan 20, 2005 | 07:05 PM
vdub08's Avatar
Default Re: oxidization owned my car... (JDM CDT)
what were u intending to do?
sand off the paint cancer then put the black primer on?
i would jsut sand off all the paint, then just spray ont he new crap. might as well do the whole car too
Old Jan 20, 2005 | 07:20 PM
mrdanglez's Avatar
Default Re: (nudvl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nudvl &raquo;</TD></TR><TR><TD CLASS="quote">PUT THE SAND PAPER DOWN AND STEP AWAY FROM THE CAR!!!!!!!!!!!!!!!!!!!!!!!!!!!</TD></TR></TABLE>
Old Jan 20, 2005 | 07:27 PM
PornoPanda's Avatar
Brake Fluid + your car = SHINEY.
Old Jan 20, 2005 | 07:30 PM
boosted420a's Avatar
Default Re: oxidization owned my car... (PornoPanda)
^ yeah, carb cleaner works wonders too.
Old Jan 20, 2005 | 10:29 PM
cedete's Avatar
Default Re: (nudvl)
wow.. 1.5 months here and already 98%...figures
anyways.... 2000 grit will do me good then?
Old Jan 21, 2005 | 04:27 PM
calxtreme's Avatar
you have to work your way up the grit scale. Use good judgement and pick one that is necessary to get the oxidiation off. I'm assuming there's probably clearcoat chipping too, so it's gonna be some work to get the layer of clear off. Once the clear is off, then use the high grit to even it out..
raverx3m
Paint and Body
May 19, 2011 05:20 PM
NEO_FOLLOWER2
Mar 21, 2011 11:55 AM
BoostedEgHatchFl
Apr 18, 2005 12:32 PM
allsho
Mar 29, 2005 04:47 PM
608 Gangsta
Aug 12, 2004 06:10 AM
