I'm hoping someone can help my EF/ 5-lug suspension woe's.....
Here's where I'm at so far:
https://honda-tech.com/zerothread?id=1059841
I'm using itr front knuckles, rear hubs, rear lca's, coilovers, and front forks.
Everything else is from stock si - including rear swaybar and front lca's, upper a-arms, etc...
Spring rates are 11k Front/ 16k Rear.....
So far my choices appear to be:
1. SiR knuckles - modified to fit the itr hub/ wheel bearing. I will need the abs specific ones. They are pricey at $400 for the set.
2. 90-91 ex sedan knuckles - modded to have the itr wheel bearing/ hub/ caliper and abs sensor mounting points welded on?
3. ???
Any other ideas?
3. ???
Any other ideas?
Darsholn
Aug 7, 2011 05:03 PM
RED_90TEG
Dec 20, 2007 12:15 PM
SiR Kid
Nov 8, 2001 06:20 PM
