adjustable shift linkage???
just picked up a 90 si with a swap $500 it has an adjustable shift linkage how do I make it right 1st is where 3rd is
Modified by works909 at 11:17 PM 1/24/2005
Modified by works909 at 6:19 PM 1/25/2005
Damn I've never heard of that?! So are you saying that your 1st gear is gated to where 3rd is supposed to be? So is your 3rd gear in 5th ear's place? Maybe give us a description of the adjustable linkage you are talking about, I have never heard of this.
maybe you have a hf tranny and the gears are so long you think 1st is in 3rd and so on when i did my motor swap i reused my hf tranny bc i was waiting on my zc tranny to come in i could do 60 mph in 1st gear and 110 in 2nd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MONSTERZC »</TD></TR><TR><TD CLASS="quote">maybe you have a hf tranny and the gears are so long you think 1st is in 3rd and so on when i did my motor swap i reused my hf tranny bc i was waiting on my zc tranny to come in i could do 60 mph in 1st gear and 110 in 2nd. </TD></TR></TABLE>
LOL that is probably the problem. Holy crap I knew the HF gears were tall, but I didn't know 2nd gear could bring you to 110
the only good thing about the hf tranny. its good for a highway run and thats about it. wanna hear something really funny when i its got my crx i took it to the track bone stock hf. i finshed the 1/4 in 1st gear shifted to 2nd right when i passed the finish line it was so fun looking back at them days now
thats crazy...my hf 2nd gear went to about 60or 70.....i never got to 110 in my hf....the fastest i got was 96 and it took me like a mile and a half to get there...i was over going 100mph cause that'd take forever
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by works909 »</TD></TR><TR><TD CLASS="quote">its a b16 and all the gears are pushed over so i only have 1-4 4th is where reverse is</TD></TR></TABLE>
Damn, did your transmission's insides somehow get fucked? That is really odd.
BUMP to see if anyone else has had this problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T »</TD></TR><TR><TD CLASS="quote">
BUMP to see if anyone else has had this problem.</TD></TR></TABLE> no the hf gears are just really really long
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MONSTERZC »</TD></TR><TR><TD CLASS="quote"> no the hf gears are just really really long</TD></TR></TABLE>
The part that is confusing me is he is saying that he has a B16 powerplant though!
there should be a way to adjust your shiftlinkage from under the car...search on it a bit, i have seen a couple of threads on them...it is probably from a company called HCP, i know they make one...maybe they have online instructions?
HTH since no one else is helping
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b2o-vtec »</TD></TR><TR><TD CLASS="quote">just picked up a 90 si with a swap $500 </TD></TR></TABLE>
wow i want a 90 si with a b16 for 500 lol
You are going to need to get under the car and begin adjusting the linkage. It is usually two rods that are thread together with jam nuts locking them in place. IMO the adjustable linkage is a royal pita. If you can't seem to fix it give hcp a call and they should be able to help you out.
I actually have that same one. Its the OLD *** HCP one. What you need to do is loosen the jam nut, put shifter in neutral and center it (Helps to have a friend hold it in place). You then adjust the length and then tighten. Tell friend to go through the gears and see if it works. If not do it again. Them things are a PITA to get adjusted sometimes.
Also make sure you tighten that jam nut really tight or your shifter will become loose and not want to go side-side into the gears. Meaning you move the shifter but the part on the tranny wont move.
92EG8
Apr 22, 2007 12:49 PM
civais
12
Apr 19, 2006 12:51 PM
