Custom EG Gauge Cluster
Old Jan 20, 2005 | 08:00 AM
Ausmith's Avatar
Default Custom EG Gauge Cluster
Some pics
Modified by Ausmith at 4:46 PM 1/25/2005
Modified by Ausmith at 4:53 PM 1/25/2005
Old Jan 20, 2005 | 08:02 AM
Discosteak's Avatar
Default Re: Custom EG Gauge Cluster (Ausmith)
wheres the tech?
Old Jan 20, 2005 | 08:07 AM
Luserkid's Avatar
Default Re: Custom EG Gauge Cluster (BADEG6)
Isnt that the super rare spoon cluster for EF thats worth like 2 grand or something? So not worth it. I could make that myself for 400 or less using Autometer.
Old Jan 20, 2005 | 08:15 AM
Ausmith's Avatar
Default Re: Custom EG Gauge Cluster (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Isnt that the super rare spoon cluster for EF thats worth like 2 grand or something? So not worth it. I could make that myself for 400 or less using Autometer. </TD></TR></TABLE>
No - I made it. It's for an EG.
Old Jan 20, 2005 | 08:17 AM
Ausmith's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG6 &raquo;</TD></TR><TR><TD CLASS="quote">wheres the tech?</TD></TR></TABLE>
Where's the tech? A custom gauge cluster is a cool piece that is fairly technical.
Old Jan 20, 2005 | 08:18 AM
BauleyCivic's Avatar
Risky Business
Pics aren't loading for me...
Old Jan 20, 2005 | 08:26 AM
Ricey McRicerton's Avatar
Default Re: Custom EG Gauge Cluster (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Pics aren't loading for me...</TD></TR></TABLE>
They just take a while.
BTW, cool looking cluster. How'd you do it?
bambbrose's Avatar
is this gonna be available to the public? i.e. are you making more than one? I saw this cluster or one with the same tach in a video of a white hatch at a raceway
Old Jan 20, 2005 | 08:38 AM
BolivianFuego's Avatar
Default Re: (bambbrose)
Damn thats pretty damn cool. I kinda want to give that a shot with my spare DX cluster. Does anyone know any nice looking tachs and speedometers? and where to get em?
Old Jan 20, 2005 | 08:39 AM
cxSHOE's Avatar
haa haa thats cool
i dont care about the write up just let me know where you got the black backing the gauges fit into. thanks hopefully you will share and not just show off
j/k thanks
Old Jan 20, 2005 | 08:40 AM
m3dia_lab's Avatar
where did you get those digital gauges? is the one on the right the speedo?
Old Jan 20, 2005 | 08:46 AM
ian.'s Avatar
Default Re: (m3dia_lab)
nice
Old Jan 20, 2005 | 08:49 AM
cxSHOE's Avatar
all the gauges are made by spa design in the uk... just follow the directions on getting them to work.
http://www.spa-uk.co.uk/design/dualgauges.htm
now lets talk about that black gauge part..
like where did you get it or how was it made if it was custom made
Old Jan 20, 2005 | 08:51 AM
Daniel san's Avatar
that's nuts yo.
is it actually functional ?
did you test it out yet ?
and if so. do you have any pictures of it in action ?
Old Jan 20, 2005 | 08:53 AM
tfalconier's Avatar
you can get all the gauges u need from Summit, the have tachs, speedos and everything else you need. Looks good, wish i had some pics of my 80 camaro on here, i made a full aluminum gauge pod with full autometers, im doing the same thing with my 88 thunderbird turbocoupe pretty soon.
cxSHOE's Avatar
oh and spoon never made a gauge cluster for the ef's (ever) just the speedo lookin sig.
Old Jan 20, 2005 | 09:02 AM
Ausmith's Avatar
Okay okay okay... enough response from the pics to post details.
1) Started with a stock DX cluster. Took it all apart and used a die grinder with barrel sander to remove the inside section. Basically left with nothing but the outer plastic.
2) Designed and cut a CF panel (1/16" 4 layer Carbon) using a band saw and various hole saws. This takes some time and decent measuring tools. Make a cardboard template first and then trace onto the CF sheet
3) Epoxied the panel to the back side of the stock housing. I did my best to get the fit of the panel close to the shape of the opening on the plastic housing.
4)The edges on the front side, where the CF panel meets the plastic housing, were all filled with bondo like material to get a nice "molded" look.
5)Sand everything very well and paint with primer and flat black paint
6)Yes this piece is fully functional. All gauges are by SPA Technique.
7)Everything, except Speedo, was wired in using the factory dash wire harness. I used a 16 wire plug that I had from a junk harness so this baby plugs in just like a factory piece.
Old Jan 20, 2005 | 09:10 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
that, is hot.
Old Jan 20, 2005 | 09:11 AM
Ausmith's Avatar
BTW.... I will take some better pics when I have time. The lighting in that room suxors and it was really bad with the flash on.
It looks really cool in the dash!
It belongs to this car:
Old Jan 20, 2005 | 09:18 AM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ausmith &raquo;</TD></TR><TR><TD CLASS="quote">
5)Sand everything very well and paint with primer and flat black paint</TD></TR></TABLE>
COOL too much work for me (no time). looks very nice although. and nice car aswell.
ill stick to my jdm/usdm itr hybrid cluster.
Old Jan 20, 2005 | 09:19 AM
mwieczorek43's Avatar
Make me one!
How much??
Old Jan 20, 2005 | 09:21 AM
bambbrose's Avatar
I'm guessing that cost over 700 just for the gauges, maybe more. and then labor, so you aren't gonna get one made for cheap
Old Jan 20, 2005 | 09:40 AM
SkRiBLaH's Avatar
how did you make a gauge for the fuel level?
that FUEL gauge is for fuel pressure, not level. wondering how you did this..
Old Jan 20, 2005 | 09:44 AM
h22a_ej's Avatar
wow thats a nice cluster...must of been a **** load of work.
good job!
Old Jan 20, 2005 | 09:52 AM
_BEN_'s Avatar
Default Re: Custom EG Gauge Cluster (h22a_ej)
That looks like boosted hybrids cluster. Nice job.
But if I could ever gather up the dough and the nerve to spend it. I would go for a stack cluster. Stack &gt; everything else
