Another NO SPARK Problem, car won't sart
ok here it goes; i have an 1993 civic si thats near fully stock w/ alotta miles on it. anyway I drive home from work 1 night, car drove fine ,next morning the thing wouldn't start. i immediatly listen for the main relay and its seems all good, then i pop the hood and check for spark and there was no spark at the plugs. i take off my distributor and swap the ignitor and no luck the car still doesn't start. take the dizzy off again and mix and match w/ another ignitor and coil. no luck with that either. the car cranks and turns over but doesn't start i can smell fuel so thats fine and no relays or fuses are blown all plugs are secure.nows were your opinions come in......what should i try next.
Is the wireharness arcing on the motor at all there maybe short? If not the distributor it could also be the computer try put a your ecu in a friends car with similiar swap, u can try to putt another ecu in yur car, or u can also do this with distributor. Also check check ign fuse (15 amp) in the fuse box in the dash and the engine bay ? Hopefully this works or steers u to the problem but if u find the problem please let me know ok?
