4 bolts holding D16Y7 water pump??
What about the one 14mm alternator bolt that is right next to the pump? Is that holding the water pump in as well? I have all 4 bolts off and that b!tch is not budging.
Thanks!
In the pic looks like it may be attached to the water pump. Look to the right and just a tad bwlow and you can see the opening for what looks like a large bolt....
Thanks!
Just to confirm the 14mm bolt must be removed as well
Timing belt installed
Water pump
Suspension
EX gauge cluster
.....all done today
Water pump
Suspension
EX gauge cluster
.....all done today
Koko4
Jun 23, 2015 11:24 AM
trendkill
Sep 11, 2014 01:42 PM
