92 DX hatch. Auto to manual Convertion w/ h22 swap tranny mount question
Do they make a H-series tranny mount (auto-to-manual) to fit in the EG's? Or will i have move the tranny bracket over and re weld
this is the only thread i found on the h22a swapped EG auto to manual conversion
https://honda-tech.com/zerothread?id=960328
From: With my POS D15B2, Whereever whenever, United States
On an EG manual, you have to cut the upper left side mount that originally held the top of the d series tranny because the place racing mounts tighten on the bottom. that should help you, I guess either way you have to cut the top of the orignal left side mount near your passenger side.
alright everyone.. I emailed haSPORT and this is what they said..
The H-Series mounts do not use the factory bracket on the passenger side. It
needs to be removed from the frame rail and then our bracket bolts to the
frame rail and supports the mount.
Hasport
wo0t!! better then i thought..
Hasport
B16Civic93
Dec 24, 2006 05:27 PM
jdmcoop
Aug 6, 2006 09:35 AM
