inside door panal
well this might sound dum but I was putting some different speakers in the front of my R and I have to take the door panal off and I took off the the screw in the right hand corner the one in the middle in the handle and the one above it inside the door opener and lock but it stil seems like it is hung up and I dont want to just ripp on it but it almost seems like that's what you have to do but I would appreciate some ideas thanks
window down. 3 screws, one in the little hand cup, one in the door handle behind a small tab, and one big plastic one towards the hinge....then go to the bottom of the door and start popping out tabs, they can be a bitch to get out. Once you do that on the bottom and sides, grab the panel by both sides and lift it up off the door, it'll be wedged on there with more metal clip goodness. once it's off, you'll have some quick connects to undo for the wires...all 3 or 4 are different, so don't worry about keeping track. voila. Getting it back on is a pain, at least getting it on the top part is...once it's lined up, just use palm strikes to pop everything back in.
suhteevin
Jan 6, 2009 09:04 PM
