ignition problems after i drove in the rain please help im so frustrated
I have a 99 honda civic hb with gsr swap from japan no spark check wires fine check coil and ignitor fine
is it even turning?
if it is.. maybe its ur spark plugs.
same thing happened to me after i got my jdm. after awhile my car couldnt start and i changed the spark plugs and it worked fine.
i check that with a electronic light spark plug tester ,also check the ignitorand coil by putting them in other honda 97 honda civic sohc and that car started fine. I M thinking its some thing else in the distributor or ecu went bad? thanks for ur input any way.
...may sound stupid/simple but make sure there's no moisture at all in the dist-cap. I had a car fail that way.
i change it at autozone and rotor but this is what weird all the gsr distributor caps at autozone didnt fit so we tried sohc 's and 95 fit ?funny huh
Noo_Ish_mee
Jun 27, 2016 02:44 PM
