lil help
im running 00 b16 in 97 hb. i used to run a p72 ecu , everything was okie but kinda sluggish. so i tried and switch to a 97 spec type-r ecu. and the engine check light went on. so i was wonder how i can check the code for obd-2 car? i knoe obd-1 cars there is a plug where you put metal wire on it would flash to tell you, any help would be apperciated. thanks
boostedjdmdc2
Dec 17, 2007 07:32 AM
GRAVEDIGGER
Jul 14, 2002 06:29 PM
