B18C1 code 48. LEAN fuel. using d16z6 fuel regulator bad?
Old Jan 19, 2005 | 07:45 PM
lazynok's Avatar
Default B18C1 code 48. LEAN fuel. using d16z6 fuel regulator bad?
swapped a B18c1 into my hatchback. It did not come with a, I tihnk it is the fuel regulator. The green bubble thing on both ends of the fuel rail. I used my green bubble things from my d16z6. Would this be causing it to run lean or would it not matter?
Modified by lazynok at 9:08 PM 1/19/2005
Old Jan 19, 2005 | 07:48 PM
hondaeg8's Avatar
Default Re: B18C1 code 48. LEAN fuel. using d16z6 fuel regulator bad? (lazynok)
i don't recall any green bubble things on the fuel rail
Old Jan 19, 2005 | 08:08 PM
lazynok's Avatar
Default Re: B18C1 code 48. LEAN fuel. using d16z6 fuel regulator bad? (hondaeg8)
pics updated. those green bubbles
Old Jan 19, 2005 | 09:52 PM
spoolindc2's Avatar
i bet taht could be it d series are sohc and dont need as much fuel, b series are dohc and need a little more... i would say try some b series "green thingys" hahaha
Old Jan 19, 2005 | 10:04 PM
snoochtodanooch's Avatar
Default Re: (spoolindc2)
the one end isn't a fuel regulator at all. Its pretty much just a nut. THe other end is the FPR, and getting one from a bseries will fix the problem.
Old Jan 19, 2005 | 10:39 PM
antivic's Avatar
Default Re: (snoochtodanooch)
uhmmm i don't think it would make a difference there both the same peice...if the fuel injectors have the same ratings i don't think the fpr has a different rating..im using a d15 fpr on my b16 and it runs fun...just sounds like firecrackers at wot...i don't think it has anything to do with the fpr though..
FunForFree33
Feb 12, 2011 01:18 PM
ldanphanl
Apr 14, 2005 08:53 AM
4door93civic
Dec 12, 2003 07:14 PM
